White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
23 registered members (Char Baby, BretK, ChrisD46, billt460, c502cid, DaleRider, 4 invisible), 801 guests, and 35 spiders.
Topics296,866
Posts4,960,388
Members66,982
Most Online2,688
Jan 19th, 2019
NGK or Champion #4665643
02/14/18 10:21 AM
02/14/18 10:21 AM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
Trying to decide the better spark plug for my 2 cycle equipment.
Champion or NGK, or does it matter?
Re: NGK or Champion [Re: doolah02] #4665661
02/14/18 10:35 AM
02/14/18 10:35 AM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
In the grand scheme of things, no , it doesn't matter.
I've had good experience with both.
But NGK is my personal preference.
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: NGK or Champion [Re: Bud_One] #4665675
02/14/18 10:49 AM
02/14/18 10:49 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
+1
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: NGK or Champion [Re: doolah02] #4665677
02/14/18 10:53 AM
02/14/18 10:53 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Use the OEM plug. I have seen the use of other plugs cause high rpm "issues". Wierd running, popping, bogging, etc. I always recommend the use of OEM plugs on 2 cycle engines. 2 cycle engines can turn 12k to 14k rpm, and the manufacturer test the OEM plug extensively.
On 4 stroke power equipment, I don't think it matters much, and I pretty much go Champion as they are cheap, made in America, and high quality, and I have never had a problem that I can remember with them.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: NGK or Champion [Re: doolah02] #4665684
02/14/18 11:00 AM
02/14/18 11:00 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Yes
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: NGK or Champion [Re: bubbatime] #4665685
02/14/18 11:01 AM
02/14/18 11:01 AM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
I have used both and haven't seen much difference, but since NGK is the OEM I'll stay with that.
Re: NGK or Champion [Re: doolah02] #4665687
02/14/18 11:02 AM
02/14/18 11:02 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Whichever brand, keep it clean, keep the electrodes sharp (sharp corners make better spark origins), gap as big as the magneto will allow w/o coil overheating. Most small engine mags will support 0.030" gaps ...
Re: NGK or Champion [Re: doolah02] #4665715
02/14/18 11:27 AM
02/14/18 11:27 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Why do you need a new plug? it should last the life of ODPE. No need to change plugs willy nilly on mild engines.
Gave away my 27 year old 8HP Tecumseh Snow blower with the original plug in near new condition. My 27 YO push mower has OE plug too. Tried a "newer" easy start briggs/hamp plug and engine ran poorly - back in went the OE plug ran fine.
Never liked extended tip plugs on flatheads. Why? Never worked right.
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: NGK or Champion [Re: doolah02] #4665723
02/14/18 11:33 AM
02/14/18 11:33 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
I never saw a big difference, especially on 4-stroke engines. I wouldn’t replace the plug unless you’re having issues. I replace them maybe every 5 years on 4-stroke, and 10 years on 2-stroke. Most noncommercial OPE isn’t used enough to foul plugs.
Re: NGK or Champion [Re: doolah02] #4665729
02/14/18 11:38 AM
02/14/18 11:38 AM
California
nthach Offline
nthach  Offline
California
It doesn't matter really. My parent's Weed Eater is using a Champion EZ-Start plug which has a bit of Pt/Ir in it. Their Echo, Stihl and Honda stuff is using NGK or Denso.
Re: NGK or Champion [Re: ARCOgraphite] #4665734
02/14/18 11:42 AM
02/14/18 11:42 AM
Canada
boraticus Offline
boraticus  Offline
Canada
I fully agree. Clean the OEM plug and put it back. I've got a 22 year old Toyota running on original plugs. I get the same mileage now as I did when the truck was brand new. Got lots of spark plugs well over 30 years old running fine.
In all of my 50 plus years of owning things mechanical, I've had only four spark plug failures. Three Champions and one NGK if I recall correctly.
Two in two cycle engines (power ice auger & chainsaw) and two in four stroke engines (snow blower Briggs engine and an NGK failed in one of my liquid cooled Suzuki ATV engines. Not bad considering how many engines I've owned. I might add that the two latest plugs that failed (one Champion and one NGK), were both relatively new.
The Champion in the snow blower actually shattered at about the 4 year mark. The NGK in the ATV was in around ten years old and it just stopped sparking.
My preference is NGK but will use Champions if I can't get an NGK. Stay away from Chinese plugs.
Re: NGK or Champion [Re: doolah02] #4666024
02/14/18 04:34 PM
02/14/18 04:34 PM
Ga
Buzzsaw Offline
Buzzsaw  Offline
Ga
NGK
Re: NGK or Champion [Re: doolah02] #4666048
02/14/18 04:56 PM
02/14/18 04:56 PM
USA
slacktide_bitog Offline
USA
NGK
Re: NGK or Champion [Re: doolah02] #4666116
02/14/18 06:33 PM
02/14/18 06:33 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The Bosch plugs that come installed in Stihl OPE last the longest of any for me.
Re: NGK or Champion [Re: doolah02] #4666569
02/15/18 08:58 AM
02/15/18 08:58 AM
N.H, U.S.A.
N.H, U.S.A.
500hrs is equivalent to much less than less than 20K miles in you car.
None of my ODPE has over 500 hrs on it in 30 years.
THATS why you don't change the plug - you don't even take it out to clean it.
If the engine has inproper fuel delivery or ignition or rings or valve seats - then it will chew plugs.
If its a healthy engine the plugs should last.
Me, on Japanese car engines the NGK Steel plugs would loose their GND straps with OE NGK by 30K miles. USA made NGK V power ran WAY WAY too hot compared to OE.
In the 90's NGK were so bad Subaru IMPORTED USA made Champion plugs for their JDM and export cars. And Toyota used ND.
NO NGK fan here, though their latest O.E. IR plugs used with COP ig seem to work. But many Japanese finally wised up and spec colder heatrange ( #6 or #7 instead of killer #5).
