Matching drywall texture
Doing some mild interior work, I found a large patch (whole wall, really - about 6.5' x 10') of drywall that was not textured with the rest of the room. There was a framed vinyl cover on the wall for a movie screen. I had thought it must have been applied after the house was finished, but I guess not!
So I am trying to match the texture to the rest of the room. In the past, my experience has been only doing smaller areas and spraying some canned Homax on it or such. This is bigger and I need to get it pretty close. I have experimented in small patches with spreading some joint compound and then dabbing it with various scotch brite pads, etc. but it's not right. I am guessing there's a kind of sponge that is common? The texture is fairly smooth - e.g., it's very rounded without peaks on the individual texture dots (which the scotch brite and others leave behind).
I think the area of the flash in this photo captures it. What should I try to do get a match to the rest of this wall and others? is spreading the joint compound like I was doing a legit way, or should I get something else?
That job is too small to hire a pro. If you have a compressor, see if you can rent a stucco gun from somewhere.
If not, spray cans or something idk. You could probably buy a gun for a what a pro would charge.
Grout sponge possibly? Or maybe a sea sponge.
Shame you don't have skip trowel which is a lot easier to mimic and hides irregularities well.
Exactly.
No way I would hire this out, it's just far too easy and I have too much experience with materials and construction, access to tools or knowledge.
I have a bunch of joint compound left over from a job two summers ago, I know I can trowel that on as mud and replicate this pattern with the right technique - which I am sure is not rocket science.
Grout sponge is what I was thinking would do this. Don't have one at the moment, have used them in the past (for grout and tile work!), can go get one. I have done some tile work in the past and I think my uncle or dad, who have done more construction work than I, told me this was common to use a grout sponge for mud texture. I had that in mind.
What's a skip trowel? I haven't heard that before. I'll go google it and see. Love learning this (or any) stuff, thanks for mentioning it.
Edit - oh, I see know - you mean skip trowel texturing with a mortar trowel. Didn't know it was called that. Yes, that would be easy-peasy to match! Yeah, this is very fine and regular so more work.
I just went through this in my massive home remodel. Go to Walmart or Lowes. They have a multitude of spray cans. Light Orange peel, textured etc.. work good and easy to apply.
Messy though but they work good.
You can try some quick drying oil base primer like Kilz or Cover stain oil primer and a 3/4" nap roller. Roll it on, let it sit for about 20-30 minutes, [when it starts to tack up] then with a damp roller [dampened with the primer] back roll into it from different angles. That should stipple it and give it that orange peel look. It's fairly easy to duplicate if you have the knack. You might have to repeat the process a few times. Depending on the depth I've also used joint compound and a carpet roller to match different textures like that. Fool around with it, I think the oil primer trick should work.
Matching drywall texture is an art. The guy who textured my house after I did a full house plumbing re pipe told me that he went to school to learn it and even after over 17 years of experience, it’s still difficult to get a uniform appearance. Either hire a professional or be happy with your results
What is that awful red on the wall . Blood ? Ketchup ?
That’s my thought. Try a heavy nap rollerbor 2 , pic the closest one. You can get quite a ripple going with the heavy nap rollers. That red color isn’t doing you any favors either as it will show tiny differences far more than lighter colors
I would re-texture the whole wall. If you want a light texture you might want to texture the untextured part as close as possible and then texture the whole wall.
With a little patience and doing as I stated above it can be done fairly easy. We've closed high hats in ceilings that had all kinds of stipple from years of painting, and when it was done no one was able to tell. The same goes for walls where windows and doors were closed up. It takes some time and patience but it can be done.
OP-The key is to let the quick dry oil primer to start to set up. Then go back into it with a damp roller, and play around and experiment. You'll see how it stipples the flat surface once you give it a try.
When you repaint the wall use at least a 1/2" nap roller. Paint the patch at least three times before coating the entire wall. Red is a PITA color to work with and can take at least three coats, possibly more to cover properly. That in and of itself will stipple the patch even more.
If that's the case, redo the entire wall. It'll look even that way.
Ok, thanks a bunch. A roller cover was another option but I couldn't figure out how it didn't "peak." I can see how letting it set up first and then rolling it would do this. I have some kilz like that on hand so I can experiment. I thought I would get to it on evenings this week, but work has been more tiring (and more of it) this week than I expected. That's why I haven't done anything yet and didn't respond to the helpful posts more quickly. I will hopefully get it done this weekend or early next week (vacation/shool break).
The existing paint on it is a base/cover with brush applique technique. Nicely done, but not for me. I know it will take a bit of work to cover it. I'll primer it before applying a final coat(s) to lighten up the room.
Question: Do I need to use the oil-based Kilz for this, or can I use heavy primer like that in a latex? (To avoid the messy clean up).
I had one qt. can of Kilz on hand and tried it. It came out great. Thanks for the advice; I would have experimented around a bit and likely not thought to use the Kilz primer as a base. I rolled it on and then came back later and re-rolled with a 1/2" nap roller and it looks good.
I did the small patches on the other walls first so I had 3/4 of the room ready to primer in case I came up short. Which proved true, so I can primer those walls today and tomorrow I'll pick up some more primer to do another texture coat. Do I need the oil to get that effect, or can I get away with something else as a base?
