March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
126 registered members (albenjoseph, 92saturnsl2, 928, 4WD, 77GrandPrix, 01rangerxl, 10 invisible), 2,021 guests, and 50 spiders.
Topics286,087
Posts4,902,304
Members67,560
Most Online2,967
Mar 10th, 2019
Update on shifting shudder... #4665440
02/14/18 06:01 AM
02/14/18 06:01 AM
Missouri, USA
Jake54 Offline OP
Jake54  Offline OP
Missouri, USA
So, after performing the maintenance myself, and doing some homework, I found out the issue was as simple as adding a few quarts to my transmission
https://www.bobistheoilguy.com/forums/ub...exp#Post4544605
A nifty how-to video was very helpful.
https://youtu.be/rUP-nOsoJMA
I bet money the shop I used had no Idea that you had to run the car in order to properly check the ATF, oh well, car is running fine now, shifting well, and Iím planning on doing a full drain and full with the next oil change.
Re: Update on shifting shudder... [Re: Jake54] #4666007
02/14/18 05:16 PM
02/14/18 05:16 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
Where did the missing fluid go ?
Re: Update on shifting shudder... [Re: Jake54] #4666085
02/14/18 06:40 PM
02/14/18 06:40 PM
Missouri, USA
Jake54 Offline OP
Jake54  Offline OP
Missouri, USA
It was never added to the transmission to be missing, i bet money the shop added fluid with the explorer off which is what you typically do with most cars right?
This model is wonkey, you have to add it while its running in order to check the proper atf level, if not it will look full with 3 quarts missing.
09 Sonata 3.3L V6 96K miles Pennzoil Ultra 5W-20 8koci
Re: Update on shifting shudder... [Re: Jake54] #4667239
02/15/18 09:06 PM
02/15/18 09:06 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
On MOST vehicles....The engine needs to be running to check ATF level. It always wise to read the owners manual.
2001 Chevy Camaro L92/4L80E
