M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
best way to buy a new vehicle?
by WhyMe. 01/15/19 11:07 PM
Cat Humor
by StevieC. 01/15/19 11:06 PM
Lightning McQueen (Humor)
by StevieC. 01/15/19 11:04 PM
Fastest Land Mammal (Humor)
by StevieC. 01/15/19 11:01 PM
Wifes says decorate the baby's room (Humor)
by StevieC. 01/15/19 11:00 PM
Taco Bell (Humor)
by StevieC. 01/15/19 10:57 PM
Van full of money (Humor)
by StevieC. 01/15/19 10:56 PM
Amazon Packaging (Humor)
by StevieC. 01/15/19 10:55 PM
Star Spangled Banner in school (Humor)
by StevieC. 01/15/19 10:52 PM
Maybe on to something? (Batman Humor)
by StevieC. 01/15/19 10:49 PM
Canadian Breakfast (Humor)
by StevieC. 01/15/19 10:48 PM
Tinder Anyone? (Humor)
by StevieC. 01/15/19 10:45 PM
(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
39 registered members (Black_Thunder, 4WD, BLND1, billt460, bourne, 4 invisible), 888 guests, and 32 spiders.
Topics296,629
Posts4,955,945
Members66,950
Most Online2,577
Jan 14th, 2019
Toyota Matrix 1.8 filter, what's with the spout? #4665399
02/14/18 01:21 AM
02/14/18 01:21 AM
Canada
expat Offline OP
expat  Offline OP
Canada
I bought a bunch of Denso oil filters from Rock Auto for our 2009 1.8 Matrix.
Strangely the filters come with an extra 'O' ring and a plastic spout.
Never had this before, is it the correct filter?
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665407
02/14/18 01:58 AM
02/14/18 01:58 AM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
I have the same setup for my 2016 Camry,the plastic spout is used to drain the cartage housing,the small o-ring is used to replace the one that is under the drain , which takes a 3/8" ratchet to remove,the large one is used on the whole cartage which take a special tool to remove. In my opinion you may have the wrong oil filter for your car,please double check!
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665619
02/14/18 09:58 AM
02/14/18 09:58 AM
WI
BlastChamber Offline
WI
Oilmutt is correct about the o-rings and drain nozzle.
I have a 2008 Vibe 1.8L that still uses a spin on filter, but I'm pretty sure that the Vibe/Matrix switched to cartridge oil filters in 2009.
'12 Toyota Camry LE Hybrid
'11 Toyota Sienna SE 3.5L V6
'08 Pontiac Vibe
'03 Dodge Ram 2500 SLT QC Cummins 24-valve
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665671
02/14/18 10:43 AM
02/14/18 10:43 AM
Canada
expat Offline OP
expat  Offline OP
Canada
I am not sure I undersand about the drain nozzle?
When I change the oil, I undo the plastic filter housing (with a special tool)
Oil pours out as the housing comes off, I remove the filter element and replace it with a new 'O' ring on the housing.
The Denso element 'looks' about the same as what I am used to seeing, except is has a removable, loose fitting plastic nozzel/spout.
I do not have an old filter to compare what I have with what I have previously used. :-(
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665690
02/14/18 11:07 AM
02/14/18 11:07 AM
New England
pda1122 Offline
pda1122  Offline
New England
This is what the bottom of the housing looks like on my tundra. Im assuming yours is about the same. The silver piece on the bottom comes off with 3/8 ratchet end. Then you stick the plastic drain thing up in there and it drains the oil from the housing. This is to make it less messy when undoing the housing. The small oring also goes in there
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665703
02/14/18 11:14 AM
02/14/18 11:14 AM
New England
pda1122 Offline
pda1122  Offline
New England
Is this your housing? Doesnt look like the bottom part comes off. Maybe Denso just threw in the extra oring and drain in as a precaution, in case you did need it. Maybe some other models have a housing more like mine
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665718
02/14/18 11:29 AM
02/14/18 11:29 AM
Canada
expat Offline OP
expat  Offline OP
Canada
Pda1122, No there is nothing to retain the filter element once the housing is removed.
Yes my housing looks like that.
The question is: Is the element the same?
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665788
02/14/18 12:30 PM
02/14/18 12:30 PM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
Got a new idea,go to AZ,AAP,or pep boys,get your oil filter in ether Fram,Mobil 1,STP, open each box the complete instructions on how to replace are in their.Take a copy home to study!
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: oilmutt] #4665790
02/14/18 12:32 PM
02/14/18 12:32 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I think you meant to use the word "there" above.
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4665837
02/14/18 01:27 PM
02/14/18 01:27 PM
VA
Rhymingmechanic Offline
VA
Maybe Denso is trying to consolidate part numbers by including the extra pieces. Or you were sent the wrong filter.
I have a '10 Vibe, and the filters from multiple brands have just the element and the big O-ring. I've never used Denso, though.
Is your part number 150-3024? Denso and Rock both show that for my Vibe, but the Denso site only has a photo of the element.
Re: Toyota Matrix 1.8 filter, what's with the spout? [Re: expat] #4666230
02/14/18 08:37 PM
02/14/18 08:37 PM
Canada
expat Offline OP
expat  Offline OP
Canada
Thanks, I will get a filter from my regular sources and 'eyeball' it against the Denso. Stands to reason they might consolidate.
