Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
81 registered members (4WD, 69GTX, 28oz, Anduril, 240_Ed, 11 invisible), 1,916 guests, and 41 spiders.
Topics295,019
Posts4,926,198
Members66,666
Most Online2,553
Oct 27th, 2018
difference between Euro and us blend of penzoil #4665141
02/13/18 07:30 PM
02/13/18 07:30 PM
Florida
gotnogunk Offline OP
Florida
Just bought a 5 gal jug of penzoil platinum for the fusion, what is the difference all SN rated.
Re: difference between Euro and us blend of penzoil [Re: gotnogunk] #4665149
02/13/18 07:35 PM
02/13/18 07:35 PM
The land of USA-made Subies!
SubieRubyRoo Offline
You found a 5 gallon jug? Where? smile
The Euros are different based on the viscosity. 0W40 is full-SAPS ACEA A3/B4 rated and good for long drains, 5W30 is low-SAPS ACEA C3 rated and not a good choice for extended drains in US gasoline engines. In a gas engine, you are probably better off sticking with plain Pennz Platinum in the correct viscosity for your vehicle.
Re: difference between Euro and us blend of penzoil [Re: gotnogunk] #4665233
02/13/18 08:46 PM
02/13/18 08:46 PM
SoCal
UG_Passat Offline
UG_Passat  Offline
SoCal
HTHS is usually a big giveaway, ACEA A3/B4 requires min of 3.5 MPa. US specs are less
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: difference between Euro and us blend of penzoil [Re: gotnogunk] #4665400
02/14/18 01:21 AM
02/14/18 01:21 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
In relation API, ACEA specs is generally more demanding in terms of engine tests requirements, additive quality and package, percentage and quality of base oils.
Having said this, Some specific API SN oils (is Mobil EP being one?) may match or exceed some 'low-end' ACEA oils with SN though.JMHO.
