I've been researching quite a bit about pre lubers, seeing that they pretty much eliminate start up wear which is important to me. However I'm having a hard time deciding which set up to choose, I'm leaning towards the geared pump. I never knew about an electric pre oiler, got idea from this video below here. Maybe I'm late to game.
https://www.youtube.com/watch?v=de4ypzHHAa8&t=118s
Advantagess of electric pump imo are
- more compact
- ability to mount in engine bay
- can use shorter hoses, therefore less pressure drop.
- Overall simpler
Disadvantages are
- Requires electrical power, the big pumps can be quite thirsty amperage wise
- A cheap chinese pump can work, but they're noisy and unreliable, USA/CANADA pumps are costly unless buying used
Advantages of oil accumulator are
- Passive system that requires little to no electricity to work
- added oil capacity
- compensates for going uphill, in tight corners etc
What are you guys thoughts?
- more compact
- Overall simpler
Disadvantages are
