VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
52 registered members (4WD, avi1777, antik, billt460, AurionX2, 97K15004WD, 6 invisible), 738 guests, and 56 spiders.
Topics286,270
Posts4,905,654
Members67,589
Most Online2,967
Mar 10th, 2019
Whatever happened to the battery eye? #4665050
02/13/18 07:08 PM
02/13/18 07:08 PM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
I haven't seen one in a long, long time. Maybe in OEM batteries, but I don't think the last two I've replaced had them.
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665053
02/13/18 07:09 PM
02/13/18 07:09 PM
Utah
CKN Offline
CKN  Offline
Utah
It's the same thing that happened to the transmission dipstick........
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665068
02/13/18 07:20 PM
02/13/18 07:20 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
It only checked one cell. You need something more than the state of one cell.
2015 Ford F250 w/Powerstroke
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665070
02/13/18 07:21 PM
02/13/18 07:21 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Racist!
2004 Corolla 130017
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665078
02/13/18 07:30 PM
02/13/18 07:30 PM
USA
mk378 Offline
mk378  Offline
USA
It was mostly for the dealer to use when evaluating the battery for warranty.
Eye dry : replace
Green ball sunk : charge, then load test
Green ball floating : OK to load test now
Also it looks like an advanced high-tech feature to the consumer.
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665109
02/13/18 08:01 PM
02/13/18 08:01 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
To lower costs kind of like most brake pads have eliminated wear indicators as they cost 2 cents per indicator. Why not stuff our pockets with the savings instead of putting those on. They can tell when the backing plate is grinding the rotor. it's all about profit and need.
I currently work with several OEM car manufacturers and it amazes me how much they need something until you tell them how much they can save by removing or eliminating it. You can't get rid of it fast enough then.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Whatever happened to the battery eye? [Re: spk2000] #4665147
02/13/18 08:34 PM
02/13/18 08:34 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
How come new cars have so much superflouus [censored] on them then? - Oh wait, I suppose it has to be cheap superfluous [censored].
Re: Whatever happened to the battery eye? [Re: Donald] #4665151
02/13/18 08:37 PM
02/13/18 08:37 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Right. Like for example, the state of no cells, and a new battery.
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665165
02/13/18 08:43 PM
02/13/18 08:43 PM
UT
BHopkins Offline
BHopkins  Offline
UT
They have went the way of the auto cassette player a long time ago, didn't they?
I only recall seeing them on Delco batteries. Did anyone else ever use them?
I recall depending upon the green eye on the first ever no-maintenance battery that I had in a car. What a disappointment. I quickly learned that there was no such thing as a no-maintenance battery, at least as far as lead-acid batteries are concerned.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665176
02/13/18 08:50 PM
02/13/18 08:50 PM
The land of USA-made Subies!
SubieRubyRoo Offline
All good guesses guys, but the real reason they got rid of the eye is because the battery beancounters determined too many people were noticing the eye was bad before the warranty expired, driving up free replacements. Eliminate the eye, and there's no way to know the battery is on its way out until it doesn't start your car, 4 days after the warranty expired. $100+ for your "pro-rated" coverage, ka-ching!
Ask me how I know....
Re: Whatever happened to the battery eye? [Re: Donald] #4665187
02/13/18 09:07 PM
02/13/18 09:07 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
this. You may have 5 bad cells but the one with the eye is ok.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Whatever happened to the battery eye? [Re: BHopkins] #4665272
02/13/18 10:08 PM
02/13/18 10:08 PM
SF Bay Area
y_p_w Offline OP
y_p_w  Offline OP
SF Bay Area
Johnson Controls can still make one if specified by the OEM. I found this photo from this thread:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3368999/2012_Honda_Civic_Battery
I can't read it too well, but the OP in that topic says the date code on the battery is 01/2012. I can make out that's it's Johnson Controls even though it's kind of low resolution. It certainly looks like a JCI battery.
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665371
02/14/18 12:37 AM
02/14/18 12:37 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
An aftermaket opportunity?
Oopps! Another money-making scheme gone west.
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665376
02/14/18 12:55 AM
02/14/18 12:55 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
My wife's 2011 Mustang factory Motocraft battery had the eye.
I replaced it with a Bosch AGM.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Whatever happened to the battery eye? [Re: y_p_w] #4665378
02/14/18 01:01 AM
02/14/18 01:01 AM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
2001 Lexus RX300 had one.
Truth alone triumphs, not untruth.
2017 Elantra SE
