Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
31 registered members (Anton93, bbhero, 4WD, bmod305, Bjornviken, 3 invisible), 491 guests, and 56 spiders.
Topics286,266
Posts4,905,502
Members67,589
Most Online2,967
Mar 10th, 2019
VW Golf charging issues #4664946
02/13/18 05:24 PM
02/13/18 05:24 PM
texas
Burt Offline OP
Burt  Offline OP
texas
My brother's 2003 VW Golf (150,000 miles+) is having charging problems that do not have obvious solutions to us amateurs:
History:
- Left lights on a couple of times at work, requiring a jump.
- Sat outside on cold weekend, wouldn't start on Monday until charged up with battery charger.
- Had a flat tire and left flashers on for a couple of hours. Car wouldn't start, Tires plus said "2 battery cells are bad".
- Went to Walmart because battery was under warranty. They said "battery needed charge but is fine - get the alternator checked"
- He's been charging it every night after 1 hour of commuting.
- Autozone said battery is drained, but alternator is putting out 13.7 volts, slightly below the 13.8-14.5 range but they think alternator is okay.
Is this something that has a common solution for this model or does it require a real technician to ferret out?
2011 RX350 59k miles
2015 Fiesta SFE eco-boost 29k miles
Re: VW Golf charging issues [Re: Burt] #4664957
02/13/18 05:40 PM
02/13/18 05:40 PM
Slovenia EU
Kamele0N Online sick
Kamele0N  Online Sick
Slovenia EU
First just check/change those on alternator(on a picture)... Sorry I dont know the name for them smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: VW Golf charging issues [Re: Burt] #4664967
02/13/18 05:54 PM
02/13/18 05:54 PM
Slovenia EU
Slovenia EU
Brushes?
Re: VW Golf charging issues [Re: Kamele0N] #4664970
02/13/18 05:54 PM
02/13/18 05:54 PM
PimTac Offline
PimTac  Offline
Brushes.
Cannot see signatures any longer so it doesn’t matter.
Re: VW Golf charging issues [Re: Burt] #4664971
02/13/18 05:55 PM
02/13/18 05:55 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
They are called brushes smile
Thick oil is better grin2
Re: VW Golf charging issues [Re: Burt] #4664979
02/13/18 06:01 PM
02/13/18 06:01 PM
Slovenia EU
Slovenia EU
Ok tnx
Re: VW Golf charging issues [Re: Burt] #4665034
02/13/18 06:57 PM
02/13/18 06:57 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Put a new regulator on the alternator the brushes are included. Like this but check the number of yours and google the part#, its an easy external bolt on.
http://www.autohausaz.com/search/product...AiABEgLIx_D_BwE
Re: VW Golf charging issues [Re: Burt] #4665065
02/13/18 07:20 PM
02/13/18 07:20 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
I don't think there's much wrong with the car. The output voltage may be on the low side. A voltage regulator may help it, or may do nothing.
Tell him to quit running his [censored] battery dead.
"Zed's dead baby, Zed's dead."
Re: VW Golf charging issues [Re: Burt] #4665088
02/13/18 07:36 PM
02/13/18 07:36 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
How do we know the charger is good? What voltage do you see from the battery charger he is using?
How clean are the terminal connections?
network down, IP packets delivered via UPS -BOFH
Re: VW Golf charging issues [Re: Burt] #4665118
02/13/18 08:08 PM
02/13/18 08:08 PM
ohio
caravanmike Offline
caravanmike  Offline
ohio
I certainly would not trust Walmart to tell me my battery is fine! I would have battery tested again.
Oils I use: Any 5w-30,5w-20 conventional
Re: VW Golf charging issues [Re: Burt] #4665121
02/13/18 08:09 PM
02/13/18 08:09 PM
Seattle, WA
spavel6 Offline
spavel6  Offline
Seattle, WA
From having similar "phantom" issues occur from time to time, I bet the battery is no good.
Go to a different Walmart, or go at a different time. The usual policy there is to not ask questions but just change out batteries when someone comes in. Or be more assertive and tell them that you've had the shop test the battery and determine it is not GOOD ENOUGH for your particular application.
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: VW Golf charging issues [Re: caravanmike] #4665131
02/13/18 08:19 PM
02/13/18 08:19 PM
Trav Offline
Trav  Offline
+ I guess I misread the post I thought AZ found 2 bad cells and Walmart changed it. Time to use the reading glasses.
Re: VW Golf charging issues [Re: spavel6] #4665257
02/13/18 10:02 PM
02/13/18 10:02 PM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
Exactly. Even a battery the readily starts the VW may cause problems. Very sensitive to voltage quality. I didn't think Wal-Mart even sold AGM batteries, of course I've never bought one except from the VW dealer. Not a bad price either.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Mobil1 0W-40
Re: VW Golf charging issues [Re: Burt] #4665370
02/14/18 12:32 AM
02/14/18 12:32 AM
utah
dareo Offline
dareo  Offline
utah
Walmarts have pretty good battery testing machines. As long as they are operated competently.
2016 Golf Wagon 5MT, 2014 Accord Sport 6MT, 2016 GMC 1500 SLT 6.2
Re: VW Golf charging issues [Re: dareo] #4665459
02/14/18 07:05 AM
02/14/18 07:05 AM
Trav Offline
Trav  Offline
Here they use a Midtronix with printer same as AA, no idea how accurate that is at determining if its good or bad.
