DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
93 registered members (2015_PSD, 4WD, 2010Civic, aleneros, ammolab, Ag76, 10 invisible), 1,712 guests, and 60 spiders.
Topics286,361
Posts4,907,079
Members67,613
Most Online2,967
Mar 10th, 2019
2013 Honda CRV TPMS Light #4664703
02/13/18 11:33 AM
02/13/18 11:33 AM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
Anyone know how to reset the TPMS light on the above vehicle? I checked the tire pressure and rotated the ties on my daughters vehicle and the light came on. I've checked the air pressures again and they are correct.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664706
02/13/18 11:40 AM
02/13/18 11:40 AM
Toronto
dgunay Offline
dgunay  Offline
Toronto
Just drive +- 50 miles and see if the light disappears. Usually Hondas calibrate tpms itself.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: 2013 Honda CRV TPMS Light [Re: dgunay] #4664712
02/13/18 11:44 AM
02/13/18 11:44 AM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
She drove about 50 miles before the light came on. On her way home the light came on and has still not gone out. I know on my 2015 Civic Si that there is a function to reset the light but I don't see that on her 2013 CRV.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664726
02/13/18 12:03 PM
02/13/18 12:03 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
For a Civic, it usually goes away within 5-10 miles.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: 2013 Honda CRV TPMS Light [Re: maverickfhs] #4664733
02/13/18 12:14 PM
02/13/18 12:14 PM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
Not really sure why it even came on after the rotation on her CRV.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664793
02/13/18 02:03 PM
02/13/18 02:03 PM
California
nthach Offline
nthach  Offline
California
The procedure to initialize the TPMS on Hondas from what the dealer techs told me and I've seen many times during a PDI was to quickly depressurize all the tires once the fuse that protects the TPMS ECM was installed. The system has to see a rapid air loss to "wake up".
The 2014-2017 Accords use an ABS-based system and probably other models - there's a menu to reinitalize the TPMS in the dash cluster's service menu accessed via the steering wheel. I would imagine the newer CR-Vs are that way too. I recall doing this on my cousin's Accord Hybrid.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664810
02/13/18 02:34 PM
02/13/18 02:34 PM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
Thanks everyone. Going to double check to make sure there is no TPMS reset within the service menu.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664888
02/13/18 03:58 PM
02/13/18 03:58 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Does this have a TPMS button on the lower left part of the dash? If so KOEO and push the button.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664892
02/13/18 04:03 PM
02/13/18 04:03 PM
GA
miden851 Offline
miden851  Offline
GA
There is A and B maintenance step access thru the vehicle maintenance info; If you rotate the tires you'll need to go there and opt for B reset; this sends the information that you did the necessary rotation and I think this will turn it off
Our CRV also have the tire pressure reset button that is used in case of an emergency, such as tire puncture or any low air pressure level in tires;
2008 Mazda6i GT; @215K miles
2016 Honda CR-V EX-L; @40K miles
Re: 2013 Honda CRV TPMS Light [Re: Trav] #4664914
02/13/18 04:33 PM
02/13/18 04:33 PM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
No, I believe that was available on the 2014+ models.
I will try that option and see what happens.
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4664962
02/13/18 05:48 PM
02/13/18 05:48 PM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
Any help here for you, says driving 30 minutes or more is needed.
Honda TPMS Reset
Re: 2013 Honda CRV TPMS Light [Re: ls973800] #4665098
02/13/18 07:50 PM
02/13/18 07:50 PM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
The light came on after driving about an hour and stayed on for the hour ride back home. I spoke with her this afternoon and she said the light went off this morning when she started the car and has not come back on.
Honda TPMS Reset
Re: 2013 Honda CRV TPMS Light [Re: Richie] #4665111
02/13/18 08:03 PM
02/13/18 08:03 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
There’s TPMS and a low tire light. TPMS is a system fault light. Low tire light is what it is. My wife’s 08 CRV had the TPMS light come on and had a faulty sensor. Ended up changing all 4.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2013 Honda CRV TPMS Light [Re: ARB1977] #4665938
02/14/18 04:09 PM
02/14/18 04:09 PM
Valencia, CA
Richie Offline OP
Richie  Offline OP
Valencia, CA
Correct it was the low pressure light that came on and eventually went out.
Re: 2013 Honda CRV TPMS Light [Re: miden851] #4665967
02/14/18 04:34 PM
02/14/18 04:34 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Huh? None of that makes sense.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
