'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
48 registered members (alcyon, Bailes1992, bcossa2001, Agnosto, Astro14, aleneros, 3 invisible), 656 guests, and 52 spiders.
Topics286,049
Posts4,901,492
Members67,551
Most Online2,967
Mar 10th, 2019
Mercedes Blue tec #4664092
02/12/18 05:31 PM
02/12/18 05:31 PM
Ontario
RogerBacon Offline OP
Ontario
I just purchased a 2010 Class 7 with a Blue Tec diesel. MB spec. is 229.51. I need help choosing a oil to run. I think I want a 0or5 W40. Our choice is limited in Canada so I am considering Mobil ESP formula or Castrol Edge Turbo Diesel. I need advice, please help.
Re: Mercedes Blue tec [Re: RogerBacon] #4664133
02/12/18 06:03 PM
02/12/18 06:03 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
In the US the correct Mobil is only about 8-9$ a quart at the dealer, which really isnt that bad for that oil required. My parts guide shows Motul 8100 XClean and Liqui Moly Top tech 4605, both in 5/30. Its also showing 229.52 as the spec, but this is US so may be different.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Mercedes Blue tec [Re: RogerBacon] #4664135
02/12/18 06:05 PM
02/12/18 06:05 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Just check the list to see if the oil is on the list. A 0w40 is probably better than a 5w40 just due to the colder climate in Canada.
http://bevo.mercedes-benz.com/bevolisten/229.51_en.html
Re: Mercedes Blue tec [Re: RogerBacon] #4664189
02/12/18 07:28 PM
02/12/18 07:28 PM
Ontario
Ontario
Mobil ESP formula or Castrol Edge Turbo Diesel are the only ones I see that might be available and I am not a fan of Mobile.
Re: Mercedes Blue tec [Re: RogerBacon] #4664225
02/12/18 07:58 PM
02/12/18 07:58 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Mobil is the preferred oil by MB. Mine even has a factory sticker under the hood recommending Mobil. I think Mobil even makes the MB branded oil.
Re: Mercedes Blue tec [Re: Audios] #4664367
02/12/18 10:35 PM
02/12/18 10:35 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
This^ buy the oil at MB. The company i work for has a ton of sprinter bluetec vans and they all get dealer serviced at 15k miles for 15 and older models and every 20k for 16 and newer units per MB. We have a couple with 300k on them that still run like new.
7G Tronic is also bullit proof trans. We do 60k service intervals at the dealer as well.
Congrats on the vehicle.
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: Mercedes Blue tec [Re: RogerBacon] #4664725
02/13/18 12:02 PM
02/13/18 12:02 PM
Illinois USA
IllinoisSparky Offline
Illinois USA
I use the MB 229.52 in my 2011 E350 BT, but the Mobil 1 ESP 5W-30 is the same thing. The bottles are molded with exact same shape, just different color!
I would go with the 5W-30. I read about a MB bulletin about some problems with the oil cooler due to high viscosity (not 100% sure).
Really, as stated above, anything on the Mercedes site is "Approved" by them, meaning it meets all of the minimum specs required for that engine. Some probably just barely meet it, others probably exceed the minimum requirement. Either way, if you use them, you should be OK for OEM oil change interval.
I personally don't like going that long (10K miles), so I cut it in half. For US, every 5k miles.
Most importantly, do NOT use biotec diesel unless you know FOR SURE that it is less than 5%.
I also like to run a double-strength dose of diesel injector cleaner, such as LiquiMoly Diesel Purge, into a tank of diesel every 3 months or so. Ours gets a lot of short trips. Not ideal for a diesel.
Good luck.
04 Ford Explorer PP 5W-30/Puro PSL
99 MB CLK320 Castrol 0W-40/M1 filter
08 MB SL550 M1 0W-40/MB
09 BMW X5 3.0i Dealer oil/filter
19 BMW 540i FF
Re: Mercedes Blue tec [Re: RogerBacon] #4665036
02/13/18 07:00 PM
02/13/18 07:00 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Contact your local Shell (probably Bluewave Energy where you are) or Imperial Oil distributor for Mobil (harder to buy Castrol direct from Wakefield) and purchase by the case, which will be the best deal. Most of these types of lubes are available only in 1 L bottles, rather than jugs in Canada, and good sales are hard to find, as is finding the product in the first place. The distributor will give you the best pricing and availability. I'd hate to see what a Canadian Benz dealer would charge for oil.
As for retail, there would be nothing more aggravating than needing say 6 litres of the product and finding Canadian Tire or Partsource with 3 litres in stock. wink
Plain, simple Garak.
Re: Mercedes Blue tec [Re: RogerBacon] #4665411
02/14/18 03:49 AM
02/14/18 03:49 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Get Mobil1 5W30 ESP.
Yet to see oil for modern diesel with performance of this oil.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Mercedes Blue tec [Re: RogerBacon] #4665460
02/14/18 07:06 AM
02/14/18 07:06 AM
Ontario
Ontario
I bought Mobil ESP 0w30 at the distributor for $8.33/lt. I think I will use the 5w30 in the summer. I don't think there can be much difference in the 2. I would like to run a heavier oil in the summer, but as of now, I can not find it.
Re: Mercedes Blue tec [Re: RogerBacon] #4665754
02/14/18 12:59 PM
02/14/18 12:59 PM
WV
loneryder Offline
loneryder  Offline
WV
Both those Mobil 1 oils are very good but I would not go 10k miles between oil changes. Also I use Power Service gray bottle in every tank. I notice a definite quieting of the engine. If I forget to add it, I notice a louder diesel clatter. Also it keeps your fuel pump and injectors clean and lubricated. Both those items are very expensive.
Re: Mercedes Blue tec [Re: RogerBacon] #4665955
02/14/18 04:26 PM
02/14/18 04:26 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
There is actually.
M1 5W30 ESP meets much more manufacturers approvals including VW 504.00/507.00 which is most stringent when it comes to wear requirements.
Also, 5W30 has ash level at 0.6% while 0W30 has ash level at 0.8%. Also, 5W30 will have lower NOACK (it is 5.6%) while 0W30 will have higher. Lower ash level, plus lower NOACK means longer DPF life. 5W30 also has pour point of -45c, so do not worry about cold performance.
Re: Mercedes Blue tec [Re: RogerBacon] #4666023
02/14/18 05:33 PM
02/14/18 05:33 PM
Garak Offline
Garak  Offline
There you go. Stick with the distributor. As for viscosity, the matter of approvals was already discussed, but as far as viscometrics are concerned, either lube is suitable for use year round. The 5w-30 will be just fine year round.
Re: Mercedes Blue tec [Re: RogerBacon] #4666431
02/15/18 06:52 AM
02/15/18 06:52 AM
Ontario
Ontario
I am going to try to exchange the 0w30 for 5w30. I like the lower ash level. I may be old school, but I think a diesel should have a heavier oil.
Re: Mercedes Blue tec [Re: RogerBacon] #4666463
02/15/18 08:01 AM
02/15/18 08:01 AM
Ontario
Ontario
The 5w30 must be better, it is almost $2 a litre more.
