Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
41 registered members (AP9, BKlab, 928, Bailes1992, Ag76, 4 invisible), 987 guests, and 35 spiders.
Topics290,920
Posts4,852,511
Members66,055
Most Online3,590
Jan 24th, 2017
Starter question #4664081
02/12/18 05:09 PM
02/12/18 05:09 PM
IL
LAGA Offline OP
LAGA  Offline OP
IL
I have a 2005 Mustang GT with 50K miles. I will be installing LT headers on it when it warms up. Since I need to remove the starter to install the headers, do you think I should replace the starter with only 50K miles or leave it in? A new starter runs about $130. The car is no longer a daily driver and will only be used on weekends now. It also has a Edelbrock supercharger which I installed last year.
Four legs good, two legs better!
Re: Starter question [Re: LAGA] #4664155
02/12/18 06:37 PM
02/12/18 06:37 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
You going to put in a chrome starter or something fancy? How hard is it to replace if you don't do it now?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Starter question [Re: LAGA] #4664178
02/12/18 07:17 PM
02/12/18 07:17 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
If the headers will make it a lot more difficult to replace the starter then it may be a good idea. Only trouble is if you go with a parts store rebuilt you will probably end up with a trashy starter that will fail sooner than if you just left the OEM one on. I think I would just keep the original on there. Maybe just clean up the terminals and such while in there.
Re: Starter question [Re: LAGA] #4664210
02/12/18 07:51 PM
02/12/18 07:51 PM
WI
HoosierJeeper Offline
WI
I'd leave the original on. 50k is pretty young, lots of life left. For sure WAY more life left than a parts store one.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Starter question [Re: LAGA] #4664232
02/12/18 08:03 PM
02/12/18 08:03 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would leave it but you may want to look into a heat shield or heat wrap for it. Ford may have something like this for yours.
https://www.amazon.com/Ford-Bronco-Expedition-Engine-Starter/dp/B000O09XC2
Or something like this..
https://www.amazon.com/Thermo-Tec-14150-Starter-Heat-Shield/dp/B00029KCWK
Re: Starter question [Re: LAGA] #4664334
02/12/18 10:02 PM
02/12/18 10:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My 1993 Ford Ranger has 284,000 - still the original starter.
YMMV, of course. Take it FWIW.
Re: Starter question [Re: Linctex] #4664391
02/12/18 11:12 PM
02/12/18 11:12 PM
Trav Offline
Trav  Offline
Headers depending on style can really bump up starter temps resulting in heat soak issues.
Over the years I find shielding the starter and steering racks on transverse mounted engines really extends the life of these components.
Re: Starter question [Re: Trav] #4664499
02/13/18 07:00 AM
02/13/18 07:00 AM
Nowhere NM
Smoky14 Offline
Smoky14  Offline
Nowhere NM
To add to Trav's post, disassemble clean and lube the starter while you have it out.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: Starter question [Re: HoosierJeeper] #4664607
02/13/18 09:51 AM
02/13/18 09:51 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
+1
50k mile factory starter has more life left in it than a parts store starter, which is what I assume you would be getting for $130. My friend has been through about 3 of those junk parts store starters on his truck. The quality is terrible, stick with the factory one if you can.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Starter question [Re: LAGA] #4664667
02/13/18 11:01 AM
02/13/18 11:01 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
X3.I bought a 48$ starter from Amazon. It was a brand spanking new clone of the Rat's original starter. The Rat doesn't see much use. Looking back, that starter started the engine less than 200 times before the armature shorted. The original starter still worked. It rattled like a maraca, due to worn out bushings. I used the armature and the solenoid from it to make a good'un. As a starter story goes, this is a fairly good one. I will eat the core charge on a rebuilt unit until I find out if the new one works better. My master strategy for my entire car fixing life is to have a parts car. stuffed behind the shop. It has worked exceptionally well. For those who don't have a parts car, get your starters,etc, from a junk yard. You know a used starter worked at one time..grin2
Thick oil is better grin2
Re: Starter question [Re: LAGA] #4664744
02/13/18 12:36 PM
02/13/18 12:36 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I too would keep the OEM starter . If you are concerned , take it apart & lube it . Then put it back together and install after the headers are in place ( leak free ) .
Wyr
God bless
Re: Starter question [Re: LAGA] #4665194
02/13/18 09:13 PM
02/13/18 09:13 PM
IL
LAGA Offline OP
LAGA  Offline OP
IL
Thanks for the input. Sorry I couldnít get back sooner. Iím going to stick with the OEM. The header pipes will be wrapped and Iíll check out a heat shield. Service the starter and reinstall.
