1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
126 registered members (2009Edge, benjy, Altima2, Bailes1992, aquariuscsm, Alfred_B, 9 invisible), 2,250 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Oil Pre luber's - oil accumulator vs electric pump #4664051
02/12/18 04:42 PM
02/12/18 04:42 PM
Virginia
Diesel_Mercedes Offline OP
Virginia
I've been researching quite a bit about pre lubers, seeing that they pretty much eliminate start up wear which is important to me. However I'm having a hard time deciding which set up to choose, I'm leaning towards the geared pump. I never knew about an electric pre oiler, got idea from this video below here. Maybe I'm late to game.
https://www.youtube.com/watch?v=de4ypzHHAa8&t=118s
Advantagess of electric pump imo are
- more compact
- ability to mount in engine bay
- can use shorter hoses, therefore less pressure drop.
- Overall simpler
Disadvantages are
- Requires electrical power, the big pumps can be quite thirsty amperage wise
- A cheap chinese pump can work, but they're noisy and unreliable, USA/CANADA pumps are costly unless buying used
Advantages of oil accumulator are
- Passive system that requires little to no electricity to work
- added oil capacity
- compensates for going uphill, in tight corners etc
What are you guys thoughts?
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664068
02/12/18 04:53 PM
02/12/18 04:53 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Skip the pre oiling nonsense.
My thoughts are your better off buying an oil with a thinner cold viscosity like a 5W40 rather than a 15W40 as an example.
Me: 13' VW GTI 3 door 6 speed manual
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: skyactiv] #4664085
02/12/18 05:21 PM
02/12/18 05:21 PM
Virginia
Virginia
I don't understand the nonsense about it. The pre oiling in the video eliminated the chain slap on the Ford ranger. It's doing something useful in his experience.
Even thinner oil won't stop the seconds of metal to metal contact at start up, sure it will reduce it, but it won't eliminate it completely.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664105
02/12/18 05:44 PM
02/12/18 05:44 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I have been using one for over 30 years in an E-150. Instant oil pressure before the turn of the key, no matter how long the engine sits. I have a dash mounted toggle switch, I flip it and watch the oil pressure build, then start the engine. I bought it because at the time my vehicle sat for weeks/months at a time without getting started. It picks the oil up from a special plug which replaces the oil plug, it goes through a very fine screen into the pump, exits the pump, and feeds the oil through a 90* fitting that goes into the area where the oil pressure sending unit goes. The oil sending unit sits on top. No matter how long the vehicle sits it starts w/o a tick or a tap, with instant oil pressure.
You can even hook it up so it starts pumping when you turn the ignition key. I like toggle switch idea better. It can also be used to cool off an engine by circulating oil prior to shutting it down.
I had this old pic hanging around from a brochure that came with it. IF you're handy and can access a pump strong enough you can probably make your own.
God Bless Our Troops
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664228
02/12/18 08:01 PM
02/12/18 08:01 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I vote for the accumulator for the reasons you list. Seems to be a clear winner.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664289
02/12/18 09:11 PM
02/12/18 09:11 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Funny it should be a marine pre-luber. This is a lot more common than people might expect.
Great thing about using those systems is that you can plumb in a valve that will alow you to use it as an oil change pump. Attach a hose, turn a switch, and power it up. Oil comes out.......fast.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: DoubleWasp] #4664490
02/13/18 06:37 AM
02/13/18 06:37 AM
NY
demarpaint Offline
demarpaint  Offline
NY
There is somewhere in the literature about the use of quick connect fittings on mine to do just that. I never bothered, but in some vehicles and marine applications it would be a big plus.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664498
02/13/18 06:59 AM
02/13/18 06:59 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
I've run both setups and the simple accumulator is the easiest. It also helps at the track with any oil starvation during high g cornering. No wiring or switches, no electronics.
Just a little tricky to get the oil level correct!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4664500
02/13/18 07:03 AM
02/13/18 07:03 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
It sounds like a scam.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4665133
02/13/18 08:20 PM
02/13/18 08:20 PM
Virginia
Virginia
Overall, the electric pump cane be done for far less if one desires. The accumulators all leave you to the mercy of overpriced gas tubes. Costs are a deciding factor for me.
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: Diesel_Mercedes] #4665451
02/14/18 06:50 AM
02/14/18 06:50 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
As long as you understand how to fix them. Wiring and control boxes and complexity galore.
Far fewer failure points on my accumulator setup...
Re: Oil Pre luber's - oil accumulator vs electric pump [Re: demarpaint] #4665622
02/14/18 10:59 AM
02/14/18 10:59 AM
WA
DeafBrad Offline
DeafBrad  Offline
WA
30 years. Wow. So how many miles on your set up now?
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
