AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
64 registered members (2003f7, Aero540T, 2010Civic, agpatel, alphadog, Aichiguy, 4 invisible), 1,281 guests, and 61 spiders.
Topics286,439
Posts4,908,173
Members67,622
Most Online2,967
Mar 10th, 2019
D-A Lubricant #4663939
02/12/18 02:35 PM
02/12/18 02:35 PM
PA
jfwalko3 Offline OP
jfwalko3  Offline OP
PA
Does anyone have experience with D-A Lube Reliant J-4 FS 5W-40? We have a couple of customers running it now and their oil analysis reports show it to be on par or better than T-6 in reguard to cumulitave wear metals, the base number does come back a little lower but the oxidation also comes back lower and it apears to have more calcium and less magnesium which I believe is a good thing.
http://www.dalube.com/pdfs/Reliant%20J-4%20FS.pdf
John Walko
John Walko
Re: D-A Lubricant [Re: jfwalko3] #4664044
02/12/18 04:36 PM
02/12/18 04:36 PM
wv
krismoriah72 Offline
wv
no help on the boutique oil..but Rotella/Mobil/Delo make fine products. Lots of stellar UOAs on these that I have seen.
Curious as to why the 5w40? Why not 10w30 or 15w40 HDEOs?
Re: D-A Lubricant [Re: jfwalko3] #4664065
02/12/18 04:52 PM
02/12/18 04:52 PM
Tn.
CourierDriver Offline
Tn.
Never have I lost an engine due to any make of oil. I have been driving since 1964 and if anyone in here was driving in 1964, we were using ancient oil designs back then as compared to the space cadet wizards in college oil engineering today..imho
no offense intended in the above statement..
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: D-A Lubricant [Re: jfwalko3] #4664176
02/12/18 07:14 PM
02/12/18 07:14 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
D-A Lube Reliant J-4 FS 5W-40. is a fine cj-4 oil that should treat you well.
High quality Specialized Lubricants pay for themselves!
Re: D-A Lubricant [Re: CourierDriver] #4664218
02/12/18 07:53 PM
02/12/18 07:53 PM
UT. USA
Dak27 Offline
Dak27  Offline
UT. USA
I have to agree with your statement. I was an infant when you started driving, but I'm friends with a gentleman who's been a heavy equipment/Semi Truck diesel mechanic since the mid 70's. I've known him before I was in my teens, - which was right about the time he started working on diesel motors. He just recently retired.
I greatly value his knowledge, so I asked him what was the "Best" brand of oil to run in my Series 60 Detroit. He told me in all his years, he never saw any evidence that one of the major brands was better than the others. He also said the only oil related failures that he'd seen were actually operator failures. Once they had a rookie mechanic forget to torque a drain plug after performing a PM, and a few Drivers over the years who failed to keep an eye on their truck's dipstick. His advise to me was use a major brand and follow Detroit's recommended change intervals.
Re: D-A Lubricant [Re: CourierDriver] #4664446
02/13/18 02:03 AM
02/13/18 02:03 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
I've never used D-A's 5W-40 oil, but I know of a 40 truck fleet that uses their 15W-40 oil (they have used D-A since the 1980s). D-A isn't known as well as the "big 3", but they certainly make quality lubes.
I think that the customers John speaks of, are quite possibly guys running oil for hundreds of thousands of miles with bypass filtration. I don't think of D-A as a boutique oil of high cost (I don't believe it's an expensive oil but not sure), it's just an oil that isn't so well known. For some of the Pittsburgh Power customers, some oils may provide a longer service interval before hitting any of the condemnation limits.
Pittsburgh Power is a fantastic company. You guys are awesome for those of us with big trucks.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: D-A Lubricant [Re: jfwalko3] #4664488
02/13/18 06:32 AM
02/13/18 06:32 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
welcome to the site!
I have no experience with DA Lubes engine oils, but I do use their (now defunct) Auto-Trans-5 (which was the clone of TES-295 ATF). Very happy with the ATF.
They were local here to Indy, but I think they have moved up to Lebanon, IN.
If you have some UOAs on it, please share and post in the appropriate sub-forum!
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: D-A Lubricant [Re: krismoriah72] #4665386
02/14/18 01:17 AM
02/14/18 01:17 AM
PA
jfwalko3 Offline OP
jfwalko3  Offline OP
PA
Definately not a "boutique oil" we can offer it for less than Rotella, Mobil or Delo.
Not sure exactly why I've gravitated to the 5w40, I've had noticable perfotmance increases using lighter oils in motorsport so I tend to go that way, if it were my personal truck I'd be running a synthetic 5w30...
John Walko
Re: D-A Lubricant [Re: dnewton3] #4665388
02/14/18 01:18 AM
02/14/18 01:18 AM
PA
jfwalko3 Offline OP
jfwalko3  Offline OP
PA
Thank you!
John Walko
Re: D-A Lubricant [Re: dustyroads] #4665389
02/14/18 01:23 AM
02/14/18 01:23 AM
PA
jfwalko3 Offline OP
jfwalko3  Offline OP
PA
Exactly, many of our customers are sucessfully extending their drains using either Harvard or OPS bypass filtration and UOA's every 25k or so.
Thank you for the kind words, we do our best!
John Walko
Re: D-A Lubricant [Re: jfwalko3] #4667484
02/16/18 08:30 AM
02/16/18 08:30 AM
Monroe,CT
Bambam Offline
Bambam  Offline
Monroe,CT
We use their gear oil in some of our equipment, fine oil at a reasonable price .
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo XLE 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
