The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
44 registered members (berniedd, 555, avi1777, aleneros, carlprop, Brad_C, 2 invisible), 602 guests, and 67 spiders.
Topics286,097
Posts4,902,482
Members67,560
Most Online2,967
Mar 10th, 2019
Mazda CX-9 startup grinding noise Advice #4663804
02/12/18 12:10 PM
02/12/18 12:10 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Hello all,
I was going to work early today and it was 44 degrees outside. Car starts up and makes a brief grinding noise like in this video.
https://www.youtube.com/watch?v=OSl3M3swnoY
Only happens when it is cold. They say it is the starter. Does this mean the starter is starting to die or is this an acceptable cold start issue? Thanks everyone.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Mazda CX-9 startup grinding noise Advice [Re: mbacfp] #4663823
02/12/18 12:24 PM
02/12/18 12:24 PM
US
JLTD Offline
JLTD  Offline
US
Could be the starter, but sounded more like an accessory bearing going bad to me.
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Mazda CX-9 startup grinding noise Advice [Re: mbacfp] #4663829
02/12/18 12:28 PM
02/12/18 12:28 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
JLTD, that crossed my mind which got me researching. Then a couple places said starter swap fixed it. Appreciate your help.
Re: Mazda CX-9 startup grinding noise Advice [Re: mbacfp] #4664193
02/12/18 07:35 PM
02/12/18 07:35 PM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
If it is the starter, I wonder if you can do what myself, and other subaru owners have done to fix their starter noises. I removed my starter and lubricated the shaft that the gear rides on, and the other moving parts in the starter. My start up noise was a little different than that noise, but maybe it's just because of the different starter design. I think the problem we had with our subies is that the starter stays temporarily engaged after the engine starts, due to lack of lubrication and the gear not moving back.
Something you could try before spending what looks like $150+ on a replacement starter.
Re: Mazda CX-9 startup grinding noise Advice [Re: mbacfp] #4664260
02/12/18 08:36 PM
02/12/18 08:36 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Thanks sxg6. Will look into that. Started it 5 more times doing errands after work. Nothing...just seems to do it when cold.
