Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
117 registered members (alphadog, Alfred_B, AdditiveOCD, AITG, 12 invisible), 1,791 guests, and 40 spiders.
Topics295,044
Posts4,926,607
Members66,672
Most Online2,553
Oct 27th, 2018
Toyota electronic throttle body cleaning #4663736
02/12/18 10:26 AM
02/12/18 10:26 AM
Albany, NY
ford46guy Offline OP
Albany, NY
I hear mixed opinions on this, some say do it, some not. The Toyota dealer says they use a brush moistened with some TB cleaner or seafoam and a shoprag. Brush it on good and leave it 10 min. Repeat if necessary. They told me not to flood it with cleaner because it could get in the electronics, just a small spray. They said you can't damage the TB if you gently push it open manually, just disconnect the connector and make sure the car is off. According to them it makes a difference. I do it with no problem on the older cars but the electronic TB worries me.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663752
02/12/18 10:36 AM
02/12/18 10:36 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Is this something they suggest you do and that they'd do for you?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663775
02/12/18 10:52 AM
02/12/18 10:52 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
On my Hyundai Gen Coupe I have pushed the throttle body open when the key was on with no problems.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663780
02/12/18 10:55 AM
02/12/18 10:55 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Id probably follow the dealers advice. I clean my TB with a heavy spray but its not electronic.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663782
02/12/18 10:55 AM
02/12/18 10:55 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Do this on Acuras all the time. Have to go in and reset the throttle adaptations after though or else the idle gets wonky.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663783
02/12/18 10:56 AM
02/12/18 10:56 AM
Nebraska
BJD78 Online content
BJD78  Online Content
Nebraska
Even if you get the TB wet it is going to evaporate and dry out quickly within 5 minutes or so.Might be a lot of smoke when you first start it up if you happen to spray a lot of cleaner beyond the butterfly, but that really wont hurt anything. Just wipe it out with a shop rag. Hard to go wrong, Just do not use throttle body cleaner on the MAF sensor. Best just to buy the CRC pack with a can of TB cleaner and a can of MAF sensor cleaner. It will last several cleanings. I clean the TB and MAF sensors about every 1-2 years and the CRC 2 can pack cost about $5-$7 max at most any part or hardware store. Of course some people like "deep creep" which also works for TB cleaning.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663787
02/12/18 10:58 AM
02/12/18 10:58 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've cleaned the TB on my Rav4 and Corolla. Used a rag and some spray. Think it was CRC throttle body cleaner spray. Used a screwdriver to drop the flap open.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Toyota electronic throttle body cleaning [Re: JohnnyJohnson] #4663791
02/12/18 11:02 AM
02/12/18 11:02 AM
Albany, NY
Albany, NY
I just stopped by a dealer and asked about the services they suggest. They said they would do a TB cleaning and spark plug service because it does not show it was done.
Then I asked about the electronic throttle and there was a tech standing there and explained it. He felt it is very important because when you idle you may use more gas if it is dirty. They also clean the MAF for that price.
They wanted $550 for the spark plugs and $150 for the TB. The spark plugs are very expensive, but I found that Denso has two identical plugs with different part numbers and they can be had for much less. They use the TT iridium plugs, I have them in my Explorer, great plugs!
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663799
02/12/18 11:08 AM
02/12/18 11:08 AM
Wet side WA
Wet side WA
That's what I thought. The Spark plugs aren't fifty dollars and a can of Seafoam at Walmart is $6 and change!
2004 Corolla 126813
2006 Duramax 74478
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663856
02/12/18 11:57 AM
02/12/18 11:57 AM
NH
supton Offline
supton  Offline
NH
I removed it on my Tundra to clean it, as I was having an idle issue. CRC cleaner of some sort, from Walmart. Haven't done on any other vehicle; I'm not sure I'd bother unless if it was easy to do, or more likely, I actually was having an issue.
2011 Toyota Camry, base, 2.5L/6MT, 170k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 195k, his
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663857
02/12/18 11:58 AM
02/12/18 11:58 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
What vehicle and engine are we talking about here? $550 for plugs on a Toyota?
Re: Toyota electronic throttle body cleaning [Re: Leo99] #4663863
02/12/18 12:05 PM
02/12/18 12:05 PM
Albany, NY
Albany, NY
The Lexus with the 2GR-FSE 3.5L engine. The plugs are $40 each and about $250 or so labor, tax.
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663865
02/12/18 12:08 PM
02/12/18 12:08 PM
California
nthach Offline
nthach  Offline
California
When I cleaned up a Toyota ETC throttle, I was able to move the plate and wipe it clean. No CEL or idle wonkiness, I think the car checks the throttle "zero" point when the PCM boots up.
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663889
02/12/18 12:35 PM
02/12/18 12:35 PM
Michigan
researcher Offline
researcher  Offline
Michigan
I've cleaned the electronic (drive by wire) throttle plate on my scion tC. What I do is clean the one side with swab moistened with throttle body cleaner. Then when I'm done with the "outside" side of the plate, I have someone turn the key to ON, but not start the car, have them press and hold the gas pedal so the plate will open up.. and I clean the other side.. Then have them release the pedal and turn the ignition off.
I have heard about messing with the "HOME" position of the plate, and usually the Toyota's will re-learn where that position is. But hey, I'm not going to force a high torque electric motor by hand. One of these throttle bodies cost around $600-700! ouch..
Another thing to think about.. DO NOT SPRAY THROTTLE BODY CLEANER DOWN THE THROAT!! On Toyota's the intake manifold on some engines is a nylon/plastic!! That means the cleaner contains acetone, you'll MELT your intake manifold! Best do you use a rag with the cleaner on it, or a cleaning swab with it on there.
another thing.. $40 for a spark plug? Highest I've seen was an NGK for a nissan at $18-20 a plug.
Re: Toyota electronic throttle body cleaning [Re: ford46guy] #4663934
02/12/18 01:32 PM
02/12/18 01:32 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Have someone press the gas pedal down while you clean.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
