What moly greaase will mixs with lucas green greas
nj
Ive been running lucas extra heavy duty grease (the green one) been using it for my tractor. Im buying a case 680e backhoe which needs a moly grease is there a good 5 percent moly grease that will mix with the lucas green grease.
ok thank you i i was thinking about going with 238 for the grease. i also think the green lucas is shear stable polyurea grease so it should work
Yea I’m running what I have on hand using the Lucas green and. Just. Oredered Schaeffers 238.
So we will se in a litlle
Figured the green might hellp push out The old harden grease first then use the good 238 for the heavy use
