As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
battleman13, Shassis, Santo, aligoodn, memyself
65275 Registered Users
58 registered (billt460, Bottom_Feeder, Boomer, BoiseBound, alarmguy, 77GrandPrix, 5 invisible), 951 Guests and 42 Spiders online.
65275 Members
67 Forums
285633 Topics
#4663709 - 02/12/18 10:03 AM Rotella T5 10w30 good to -25C/-13F
Duffyjr Offline
Loc: Nebraska
Thinking about using T5 in my pickup for the April-Nov fill and ran across this at the Shell site. Says the 10w30 is good down to -25C.
http://rotella.shell.com/products/t5.html
What makes the T5 better at lower temps than other 10w30's at 0F?
89 GMC Sierra T5 10w30/Wix
08 Lucerne Mobil 5000 5w30
99 LeSabre QSGB 10w30/TG
18 Toro Super Recycler T5 10w30
#4663718 - 02/12/18 10:09 AM Re: Rotella T5 10w30 good to -25C/-13F [Re: Duffyjr]
2004tdigls Offline
Loc: maple ridge, bc
it has a synthetic base stock
#4663826 - 02/12/18 11:26 AM Re: Rotella T5 10w30 good to -25C/-13F [Re: 2004tdigls]
Duffyjr Offline
Loc: Nebraska
Yes sir I get that synthetics flow better but of all the sites I've been to reading up on 10w30's the Shell site is the only one comes out and gives an actual temp. Most other sites the only thing I see is pour points which I've learned here is not a good indicator of how well the oil will work in colder temps. But the pour point for the T5 (-42C) is better than say Durablend (-33) so I was wondering why is all.
#4663995 - 02/12/18 02:38 PM Re: Rotella T5 10w30 good to -25C/-13F [Re: Duffyjr]
Nederlander75 Offline
Loc: CO
Probably nothing makes it better than other 10w30s unless it goes longer without slipping a grade as they are allowed to do. They all pass the same tests to qualify for their grade.
#4663997 - 02/12/18 02:40 PM Re: Rotella T5 10w30 good to -25C/-13F [Re: Duffyjr]
OVERKILL Offline
Loc: Ontario, Canada
10W-30 is rated at:
-30C for MRV (pumping)
-25C for CCS (cranking)
This is regardless of who manufactures it, it must test below the limits for those two qualifications to be classified as a 10W-xx.
2016 Durango Limited
2016 Grand Cherokee SRT
#4664655 - 02/13/18 09:49 AM Re: Rotella T5 10w30 good to -25C/-13F [Re: Duffyjr]
ChrisGuerrero Offline
Loc: Houston, TX
Hi @Duffyjr, Rotella T5 10W-30 (Synthetic Blend) is enhanced with synthetic base oil plus advanced additive technology for better low temperature flow (Note: pour point at –42 degC/–43.6degF). The effect: minimizing wear for better engine protection and easy cranking during cold start-ups as it easily flows towards the critical engine parts. Hope this helps!
#4665079 - 02/13/18 06:31 PM Re: Rotella T5 10w30 good to -25C/-13F [Re: Duffyjr]
Garak Offline
Loc: Regina, Saskatchewan, Canada
It's always important to note what "other" 10w-30s to which you're comparing. If it's an ILSAC 10w-30, the MRV and CCS numbers of the ILSAC lube will be considerably better. It would be best to compare the T5, of course, to its legitimate competition.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
