How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
67 registered members (69Torino, Ablebody, Bandito440, andyd, aquariuscsm, 10 invisible), 1,219 guests, and 34 spiders.
Topics290,738
Posts4,849,392
Members66,033
Most Online3,590
Jan 24th, 2017
Replace Thermostat? #4663538
02/12/18 08:07 AM
02/12/18 08:07 AM
Illinois
carguy996 Offline OP
Illinois
My 2005 Envoy through a P0128 code a couple weeks ago which came back as a thermostat code. I reset the code with my Blu Drive reader and it hasnt come back since. I also have been watching the real time temp readings, the car warms up quick, heat is nice and hot and the temp gets to around 185, drops to 176 and stays consistent at 185, the dash gauge reads at the 210 level and since its really cold out, will drop if I am stopped idling and warm back up when driving. I also pulled the radiator cap when cold and there is no movement of the coolant which to me would presume the thermostat is working.
Normally I would just replace the thermostat and be done but this car is a pain and requires removal of the alternator and other parts to get at the thermostat so I dont want to mess with it unless it really is a problem. Should I consider the code to be a 1 time thing and go with it or just take on the job and get it done?
Thanks!
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
Re: Replace Thermostat? [Re: carguy996] #4663549
02/12/18 08:16 AM
02/12/18 08:16 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
I own a 2006 SRT8 which will occasionally throw a PO128 code when it gets cooler. It takes 3 slow warm ups to get the code set and usually 3 good ones will turn it off automatically. Looks like nothing to worry about to me...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Replace Thermostat? [Re: carguy996] #4663555
02/12/18 08:21 AM
02/12/18 08:21 AM
Atlanta, GA
RoGuE Offline
RoGuE  Offline
Atlanta, GA
My Malibu temp gauge stayed on cold one morning back in September. It showed a P0128 code. I later changed the thermostat and it was definitely bad, the inner rubber seal was gone.
2007 Chevrolet Malibu
2.2L Ecotec
Re: Replace Thermostat? [Re: carguy996] #4663557
02/12/18 08:24 AM
02/12/18 08:24 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It could be a coolant temp sensor or contact issue also, cold weather can wreak havoc with contacts and connections.
If the sensor is easy to get at I would check for moisture or water ingress and clean the contacts with a contact cleaner and see how it goes. As it has good heat and the thermostat seems to be functional I doubt the thermostat has failed then started working again.
Re: Replace Thermostat? [Re: carguy996] #4663562
02/12/18 08:30 AM
02/12/18 08:30 AM
Illinois
Illinois
I thought about the coolant temperature sensor, its in the same place as the Thermostat so its recommended to do both on this particular motor. Since its seems ok for now, ill let it go the rest of the winter and tackle this job when its a little warmer in the spring. This is mostly a winter car for us because of the 4wd and only used in the summer to pull a popup camper. Its starting to need some other repairs so it may get to the point where I just sell it since its starting to become a money pit!
Re: Replace Thermostat? [Re: carguy996] #4663577
02/12/18 08:46 AM
02/12/18 08:46 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Get some cardboard and put in front of the condenser.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Replace Thermostat? [Re: carguy996] #4663591
02/12/18 09:09 AM
02/12/18 09:09 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
I’ve dispensed this advice in the past and it has helped some folks make the decision on the thermostat. Buy one of those infra red temperature guns with the laser pointer. Check the temps of the “hot” engine at the thermostat housing, radiator, and engine block. See how close this is to what your gauge is indicating.
SF
If you want the job done right......do it yourself.
Re: Replace Thermostat? [Re: carguy996] #4663597
02/12/18 09:19 AM
02/12/18 09:19 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I don't see any impending reason to change it immediately; but due to its age and this anomoly, I would put in on a list to replace sometime in the future when its convenience for you.
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Replace Thermostat? [Re: carguy996] #4663716
02/12/18 11:09 AM
02/12/18 11:09 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I would not change out the thermostat on this car.
Re: Replace Thermostat? [Re: carguy996] #4663717
02/12/18 11:09 AM
02/12/18 11:09 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
The last thermostat I did on a trailblazer/Envoy I didn't follow the service manual that says remove generator. I just removed the wheel and inner fender liner and it's right there.
Re: Replace Thermostat? [Re: carguy996] #4663754
02/12/18 11:37 AM
02/12/18 11:37 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Last time I changed out a bad thermostat on a car that was running cold, the gas mileage improved afterwards. You just have to weight that with the difficultly of removing it and see if it's worth the extra gas mileage. I think it has to register cold several times before it trips a code so it's probably only a matter of time before it comes back.
Re: Replace Thermostat? [Re: carguy996] #4663774
02/12/18 11:50 AM
02/12/18 11:50 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Do not rely on factory gauges but us a OBDII data reader.
Re: Replace Thermostat? [Re: GMBoy] #4663920
02/12/18 02:12 PM
02/12/18 02:12 PM
Illinois
Illinois
Thank you for that advice, Ill take a look into it!
Re: Replace Thermostat? [Re: carguy996] #4664173
02/12/18 07:12 PM
02/12/18 07:12 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
You're welcome. It's about a 40 minute job this way. Remove the inner plastic wheel liner and it's wide open. Report back with your results.
