"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
71 registered members (A1O, aloe2018, AdditiveOCD, ARB1977, aircooled, arowbat, 8 invisible), 1,349 guests, and 54 spiders.
Topics286,321
Posts4,906,383
Members67,599
Most Online2,967
Mar 10th, 2019
Heat Shrink Sleeves for Frantz and MotorGuards #4663323
02/11/18 09:06 PM
02/11/18 09:06 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Hey guys,
On a previous post the topic of sleeves was discussed and ranged from metal to o-rings to heat shrink. I've always machined either aluminum or stainless sleeves in the past for my Frantz and MotorGuards. Jacobs commented that he used heat shrink and I thought is was such a great idea I would try it out. Saves me about 4 hours lathe time making sleeves so worth the time to test this out. I bought 2 feet of CANUSA CFTV-1700 from ebay and installed on the top half of my MotorGuard M100, bottom half is a pressed aluminum sleeve. The heat shrink is rated from -46 to 266 degrees f, which should be fine for my application. Took 2 layers of tubing to fit nicely to the centre tubes of Kirkland brand rolls. Here's some pictures:
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4663334
02/11/18 09:20 PM
02/11/18 09:20 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Very cool! It seems to be a big time saver.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4663482
02/12/18 03:44 AM
02/12/18 03:44 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Never had a Frantz and so don't really understand what this is for.
Do the TP rolls you are using not fit the kit as-is?
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: Ducked] #4663682
02/12/18 10:37 AM
02/12/18 10:37 AM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
No, Frantz was made in the day when toilet paper cores were 1.5" in diameter. Today the rolls are 1.6" to 1.7" in diameter so the center tube will not seal well to the new rolls. You can still get rolls from the new company that bought the rights to manufacture the Frantz brand. They address the 1.5" inch tube issue by making 1.5" cardboard sleeves that they put in the 1.6" cores. They then wrap it in a nylon gauze and sell them for $4.95 USD so you think they are something more than a toilet paper roll. I bought 2 of these rolls from them to see how they were made and performed against a normal store brand rolls. They are definitely wrapped tighter than store brands, but I could not see any better performance. I ended up using Kirkland brand rolls for both the Frantz and MotorGuard filters I run.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4664292
02/12/18 09:15 PM
02/12/18 09:15 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Thanks. Makes sense.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4668527
02/17/18 09:28 AM
02/17/18 09:28 AM
Florida Ma.
Ducati996 Offline
Ducati996  Offline
Florida Ma.
Iíve used the amsoil dual bypass filter in the past and once again discovered the Frantz system.
Being a total bypass system is there a restriction in the system to control Oil flow or is the (tp) filter element the restriction?
90cummins
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: Ducati996] #4668794
02/17/18 03:20 PM
02/17/18 03:20 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
90cummins
Yes the Frantz uses a .062 or 1/16" orifice to limit the oil flow.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4668888
02/17/18 04:57 PM
02/17/18 04:57 PM
Florida Ma.
Ducati996 Offline
Ducati996  Offline
Florida Ma.
Thank you.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4671769
02/20/18 11:29 AM
02/20/18 11:29 AM
ranches in Sierra Nevada Calif...
valley_ranch Offline
A310 ~ RE: the shrink tube ~ when you remove the filter ~ at oil change ~ does the shrink tube stay on the post ~ or come out with the filter each time ??????
Can't tell by the picture ```
Thank you
Richard
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: valley_ranch] #4673551
02/21/18 06:04 PM
02/21/18 06:04 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Thank you
Richard
I just installed the heat shrink with the idea that it will stay on the tube when I pull the roll out. It's good heat shrink with an adhesive coating so when it's heated and shrinked, it bonds to the center tube. I'll know on the next change in 5000 miles and update on the findings. eek
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4679651
02/27/18 01:02 PM
02/27/18 01:02 PM
A310 ~ Thanks for the response ~ I'll look forward to hearing ~how that works out ```
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4718935
04/06/18 09:41 PM
04/06/18 09:41 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
I changed out the filter the other day and took a sample for Blackstone labs. The center core sealed very well, in fact so well the toilet paper core attached itself to the heat shrink and was very difficult to remove. I added a little grease on the heat shrink this time when I put the the new toilet roll in. The heat shrink itself is in perfect condition and shows no sign of deterioration. We'll see how the greased center tube behaves.
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4719060
04/07/18 02:15 AM
04/07/18 02:15 AM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
That's interesting--how do you think the grease will affect the analysis?
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: AlaskaMike] #4719360
04/07/18 10:26 AM
04/07/18 10:26 AM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
I'm not sure, I'll find out the next sample I take. blush I'm sure some of it will leach out into the oil, might make for an intersting oil analysis.lol
Re: Heat Shrink Sleeves for Frantz and MotorGuards [Re: A310] #4760522
05/18/18 02:42 AM
05/18/18 02:42 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
Im doing same on my frantz I ordered some high temp 3:1 shrink sleeve, Im very worried about breakdown from fuel/oil over time rubber/plastic/glue. That is only item that has me concerned granted that will show in oil analysis but is it worth taking chance on 8k engine to save 4$ on frantz TP roll?.... Still debating on that. I gotta put some more miles on truck to get UOA then do shrink wrap for short 5k run and see what UOA shows.
16 Silverado 2500 LML 20k Miles
Rotella 5w-40 T6
ST 75w-90 GL5 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
