I have an electric motor with a gearbox that calls for Klubersynth UH-1-460
Does anyone know if there’s a more readily available 460 weight oil I can use?
The motor is on a stretch wrapper and is a Baldor. The gearbox is also and has a 40:1 ratio and produces 680 in. lbs or torque from .674hp input.
