Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
19 registered members (billt460, ctechbob, dlundblad, avi1777, cjolson140, 2 invisible), 542 guests, and 55 spiders.
Topics286,171
Posts4,903,552
Members67,572
Most Online2,967
Mar 10th, 2019
Oil substitution help. #4661600
02/10/18 07:24 AM
02/10/18 07:24 AM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
I have an electric motor with a gearbox that calls for Klubersynth UH-1-460
Does anyone know if there’s a more readily available 460 weight oil I can use?
The motor is on a stretch wrapper and is a Baldor. The gearbox is also and has a 40:1 ratio and produces 680 in. lbs or torque from .674hp input.
2003 Honda Accord: Mobil 1 high mileage 0w-20
Re: Oil substitution help. [Re: Elijah1] #4661618
02/10/18 08:01 AM
02/10/18 08:01 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Oil substitution help. [Re: Elijah1] #4661699
02/10/18 09:54 AM
02/10/18 09:54 AM
lllinois
salesrep Offline
salesrep  Offline
lllinois
This is a food grade and also, very importantly a poly- glycol base which will NOT mix with other bases w/o a meticulous purge.
Kluber data sheet
sew euro drive crosses
Do you need food grade? Switching to a pao base fluid MAY work with a great purge.
Schefers Syntheic Food Grade gear oil 276
High quality Specialized Lubricants pay for themselves!
Re: Oil substitution help. [Re: salesrep] #4661704
02/10/18 09:57 AM
02/10/18 09:57 AM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
Food grade is not a consideration. Purging with what chemicals?
Re: Oil substitution help. [Re: Elijah1] #4661714
02/10/18 10:05 AM
02/10/18 10:05 AM
lllinois
salesrep Offline
salesrep  Offline
lllinois
If fg is not a deal than a high grade iso 460 gear oil cross. Several to choose from. pm me if interested in Schaeffers gear oils.
mineral, semi,straight pao are all available.
I use Schaeffers 131 Neutra, i am sure there are others. drain. Run cheap mineral oil thru with the purging agent. Short cycles.Repeat. Repeat,
Poly and traditional oils will turn to jelly.
Re: Oil substitution help. [Re: salesrep] #4661884
02/10/18 12:33 PM
02/10/18 12:33 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
repeat and repeat again!
If this is a worm drive reduction box, that oil is so thick (worse than STP) and they are not easy to "flush"
Re: Oil substitution help. [Re: salesrep] #4661945
02/10/18 01:33 PM
02/10/18 01:33 PM
NE Indiana
Elijah1 Offline OP
Elijah1  Offline OP
NE Indiana
Were it my equipment and not my employer’s I’d buy Schaeffers, but my boss will likely get whatever Grainger sells
