Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
87 registered (Astro14, Atesz792, Al, andyd, 92saturnsl2, 11 invisible), 1537 Guests and 31 Spiders online.
65294 Members
67 Forums
285781 Topics
#4661512 - 02/09/18 11:55 PM whats the up size for XG9688
Skanky Offline
Loc: Wa
for 2014 Lancer Evo 2.0 L??? has anyone used the XG 7317??? Or what is know to fit work.
#4661523 - 02/10/18 12:55 AM Re: whats the up size for XG9688 [Re: Skanky]
Linctex Offline
Loc: Waco, TX
XG 7317 is "typically" the largest XG size...
If you have the room, Baldwin makes a couple even larger.
But really, if the "7317 size" can handle a 5.3 Chevy V8, I think it can handle your Mitsu.
#4661590 - 02/10/18 05:51 AM Re: whats the up size for XG9688 [Re: Skanky]
dlundblad Offline
Loc: Indiana
The 7317 and 9688 are very close in terms of filter media. I would run whatever is spec'd personally.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4661634 - 02/10/18 07:25 AM Re: whats the up size for XG9688 [Re: Skanky]
SHOZ Offline
Loc: Illinois
Here's some XG9688 replacement specs.
Fram Hyundai fit spin on filters
XG6988 same as OE size.
Anti-Drainback Valve YES
Base Gasket I.D. 2.13
Base Gasket O.D. 2.42
Base Gasket Thickness 0.2
By-Pass Valve Setting 9-15
Height 3.08
Inside Diameter 20mmx1.5mm Th'd
Outside Diameter 3.02
Style 1
XG3593A
Base Gasket I.D. 2.125
Base Gasket O.D. 2.422
Base Gasket Thickness 0.203
By-Pass Valve Setting 12
Height 3.39
Outside Diameter 3.016
Style 1
Turning Specification 3/4-1
XG7317
Base Gasket I.D. 2.218
Base Gasket O.D. 2.484
Base Gasket Thickness 0.281
By-Pass Valve Setting 13
Height 3.469
Outside Diameter 2.688
Style 1
Hyundai Accent L4 1.5 [1995-1999]
Hyundai Tiburon L4 2.0 [2003-2003]
XG3985
Base Gasket I.D. 2.469
Base Gasket O.D. 2.75
Height 3.688
Outside Diameter 3.656
Style 1
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4662158 - 02/10/18 04:51 PM Re: whats the up size for XG9688 [Re: Skanky]
69Torino Offline
Loc: Indy
K&N HP-1004. It is a bit longer than a 9688. The Evo guys that come into my dealership love the things. I use them on my 2015 Kia Optima.
Apparently I own too many cars and toys to fit in a signature.
#4662383 - 02/10/18 10:34 PM Re: whats the up size for XG9688 [Re: Skanky]
Skanky Offline
Loc: Wa
I have some XG7317 so was hoping to use them up. However its odd the 7317 has a 13 psi BP and the 9688 has a 9-15 psi bp. Why the huge range on the 9688? Seems odd it has two numbers but the rest have one single number?? The 3593A looks to be the closest upsize but as mentioned by others why not just use the 9688 spec. Just wanted to know if using up the 7317 was possible I'm still wondering.
#4662388 - 02/10/18 10:52 PM Re: whats the up size for XG9688 [Re: 69Torino]
Skanky Offline
Loc: Wa
Being a new EVO family I have to ask was there problems with other filters in the EVOs? Lifter noise etc???
#4662389 - 02/10/18 10:56 PM Re: whats the up size for XG9688 [Re: Skanky]
ZeeOSix Offline
Loc: PNW
Since 13 PSI is about in the middle of the 9-15 PSI range, they are basically the same. If the 7317 physically fits in the mounting location I don't see any reason it wouldn't work.
The base gaskets aren't exactly the same size, but if the filter mount has a decent sized flange it should still work. I'd inspect the filter mount carefully when the filter is off, and put a thin layer of grease on the 7317 gasket and spin it on to just kiss the mount, remove it and see what kind of footprint the greased gasket left to determine if the 7317 gasket size works OK on that engine.
9688
7317
#4664138 - 02/12/18 05:07 PM Re: whats the up size for XG9688 [Re: Skanky]
69Torino Offline
Loc: Indy
No, they just like the fact that they are built sturdy with high flow media. Some Rally-X guys. They like that they can take rock hits.
#4666237 - 02/14/18 08:42 PM Re: whats the up size for XG9688 [Re: Linctex]
Skanky Offline
Loc: Wa
7317 is not the spec for my 2014 5.3, does it fit some, its not even close on the seal dia. I had not even considered it for my truck am I missing something?
Edited by Skanky (02/14/18 08:42 PM)
