Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
37 registered members (CKN, Blkstanger, ammowaster, 2strokeNorthstar, aquariuscsm, 3 invisible), 1,028 guests, and 46 spiders.
Topics295,090
Posts4,927,623
Members66,684
Most Online2,553
Oct 27th, 2018
Hankook Kinergy Noisy #4661156
02/09/18 04:13 PM
02/09/18 04:13 PM
Toronto Canada
Spider Offline OP
Spider  Offline OP
Toronto Canada
I bought a new Cruze LT with the RS option which was delivered with Hankook Kinergy tires that I found extremely noisy, I complained and the GM dealer said that they were just fine, not a problem at all. Easy for them to say.
I replaced them with snow tires on their own rims and sensors and the noise magically disappeared completely.
The Hankook tires (about 2500 miles) are in my basement now where I took a closer look at them and discovered coloured lines in the tread area (not paint) all around each of the 4 tires. Misaligned belts? I contacted Hankook here in Canada earlier this week but have not had a reply yet.
Anybody ever heard or seen such a thing?
Spider
Re: Hankook Kinergy Noisy [Re: Spider] #4661174
02/09/18 04:55 PM
02/09/18 04:55 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Those tires appear to have way more than 2500 miles on them how deep is that tread?
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Hankook Kinergy Noisy [Re: JohnnyJohnson] #4661220
02/09/18 05:50 PM
02/09/18 05:50 PM
Toronto Canada
Spider Offline OP
Spider  Offline OP
Toronto Canada
Tread depth measured with machinists calipers at various locations on a couple of tires is about .225" to .250".
Thanks for your input.
Re: Hankook Kinergy Noisy [Re: Spider] #4661226
02/09/18 05:54 PM
02/09/18 05:54 PM
USA
slacktide_bitog Offline
USA
welcome
OE tires are not the same as aftermarket tires you'd buy from Tire Rack, DT/DTD, Walmart, or your favorite tire shop, even when they have the same name.
The OEM just wants cheap LRR tires to meet CAFE targets and will install any piece of plastic to get the highest numbers crzy
Re: Hankook Kinergy Noisy [Re: Spider] #4661419
02/09/18 09:33 PM
02/09/18 09:33 PM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Nope, that is indeed paint. It's used to identify tires that are the same - because other tires will have a different color combination. Makes it easy to see if you have an odd tire in the stack.
And - Nope - nothing to do with noise generation or anything other than quick identification.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Hankook Kinergy Noisy [Re: CapriRacer] #4661746
02/10/18 09:41 AM
02/10/18 09:41 AM
Toronto Canada
Spider Offline OP
Spider  Offline OP
Toronto Canada
Barry, nice web site.
Drawing on your expert experience do you have any suspicions on what would cause the roar of the Hankooks to disappear completely when they are replaced by snow tires that should be a little noisy but aren't.
A simple observer like me is convinced that the problem is the tires. I will see that they are rotated when they are put back on the car this spring but what do I do if the roar returns? Replace them at my expense?
Thanks for your time
Spider
Re: Hankook Kinergy Noisy [Re: Spider] #4661990
02/10/18 01:41 PM
02/10/18 01:41 PM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Spider
There are parts of this that do not make sense.
As a general rule, OE tires - the tires that come on new vehicles from the factory - are generally designed to be quiet - ish. I can not imagine GM allowing a basically noisy tire through their process. On the other hand, I gather that this vehicle was designed in Korea, so maybe the GM engineers didn't have the power (or didn't know about it) to overrule the Korean design team.
Another thing that doesn't make sense is that the winter tires are quieter.
So is it possible that the noise only appears bad on one particular road? That has been known to happen.
If that is the case - and even if the noise is there pretty much all the time - then, yes, you are going to have to replace the tires. I would start with the dealer where you bought the car. If they won't help you financially, then call Hankook's 800 number and talk to them.
CapriRacer
Re: Hankook Kinergy Noisy [Re: CapriRacer] #4664330
02/12/18 08:57 PM
02/12/18 08:57 PM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
We have those tires too on our 2017 Cruze Hatchback, and they aren't particularly noisy. Granted I have two small children in the back seat, so the tire noise may not be discernable over that generated by my offspring.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2017 Chevy Cruze Hatchback 1.4L (LE2) Mobil 1 5w30 w/ Wix
Re: Hankook Kinergy Noisy [Re: CapriRacer] #4664399
02/12/18 10:21 PM
02/12/18 10:21 PM
SoCal
UG_Passat Offline
UG_Passat  Offline
SoCal
Spider
Be prepared to be disappointed in reality of GM
https://www.freep.com/story/money/cars/mark-phelan/2018/02/08/gm-tires-buick-regal-tourx/313763002/
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
