Originally Posted By: MolaKule
Originally Posted By: jgscott
Thank you, but would not the detergency be used quite a bit in the old oil before a oil change? Thus the New Trans fluid having detergency a bit more? I think someone here even posted that trans fluid really didn't have detergency, but I declined to respond. According to the inquires I have made with Manufacturers who make it, it has quite a lot.
You did not respond because you have no lubrication engineering data to support your wild theory.
Please inform us as to the exact question you asked them and which manufacturers have stated that ATF has more detergents than present day motor oils, and please quote them Verbatim so nothing gets lost in your translation.
I also think its better than oil and aids in the engine seals too.
Hope its ok to respond to you without risking getting banned. Thanks
What is better than oil? What are you talking about?
If you dare read past threads about the components in engine oil additives, you will see it has engine seal conditioners.
You have gone way past your original topical question and now you are bringing up fairy tales and uninformed theories.
Now that your question has been answered, it's time for you to go tighten some Lugnuts.
Note that I am not bending your arm to post, be your obvious frustrations.
