Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
108 registered members (AndyB, ArrestMeRedZ, addyguy, avi1777, 10 invisible), 2,062 guests, and 58 spiders.
Topics286,152
Posts4,903,059
Members67,565
Most Online2,967
Mar 10th, 2019
School me on the DCT #4660844
02/09/18 11:54 AM
02/09/18 11:54 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Ever since I first encountered the term dual clutch transmission I've wondered what was good about having 2 clutches? What makes a DCT work? . TIA
Thick oil is better grin2
Re: School me on the DCT [Re: andyd] #4660861
02/09/18 12:08 PM
02/09/18 12:08 PM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
You know about input shaft/lay shaft/output shaft and the sliding mesh gears?
Well imagine two concentric input shafts, one has gears 1,3,5 other shaft has gears 2,4,6. Each shaft has its own clutch and can 'preselected' the next gear so it only has to change from one concentric input shaft to the next.
There's some cool animations on YouTube
Cable ties should hold it
Re: School me on the DCT [Re: andyd] #4660866
02/09/18 12:10 PM
02/09/18 12:10 PM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Re: School me on the DCT [Re: andyd] #4660903
02/09/18 12:46 PM
02/09/18 12:46 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I have read up on the problems with the Dual Clutch Transmissions on the Ford Escape and Focus .
Those transmissions give the appearance of an automatic , but are more a semi-automatic transmission under electronic control . Do not think they have the torque converter , like the traditional automatic . Maybe no planateraries or " wet clutches " .
This last summer when we were shopping for a used car , I ruled out the Focus because of the history of problems with the transmissions .
I think the Dual Clutch transmission is suspose to be more fuel efficent than the traditional automatic ?
Wyr
God bless
Re: School me on the DCT [Re: WyrTwister] #4660912
02/09/18 12:58 PM
02/09/18 12:58 PM
NH
supton Offline
supton  Offline
NH
Yep. Never in a slippage region like an unlocked torque convertor. I think all the controls are electromechanical? conventional automatics use a fluid pump to generate pressure; but in order to have sufficient pressure at low engine rpm means it's bleeding lots of pressure off at high rpm. [Pump is driven off the engine, so that the transmission will work at idle.]
IIRC first & reverse are usually pretty low, so as to get around having to slip the clutch a lot.
It's a pretty cool idea. Just one that seems to have had a few teething issues--good idea, and some bad implementations it seems.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: School me on the DCT [Re: andyd] #4660919
02/09/18 01:08 PM
02/09/18 01:08 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I think the biggest problem with DCTs is that people get them and drive them like traditional automatics (with the same expectations).
A lot of the complaints probably have to do with how the DCT prepares the next gear. If you drive in a manner that is not consistent with how a DCT is programmed then you're going to think it's clunky and inefficient.
Burnt clutches would be another issue. The mfrs should only use wet clutch DCTs for consumer vehicles. This might give it a fighting chance to survive when the car is held up on a hill with just the gas pedal.
Re: School me on the DCT [Re: andyd] #4660925
02/09/18 01:14 PM
02/09/18 01:14 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Thank you, Olas. I kept waiting for the the guy's beard to get caught in the gears. And DCT are "good" because they shift faster? Further wikipedia informs me that they are used in everything on wheels.
Re: School me on the DCT [Re: andyd] #4660938
02/09/18 01:27 PM
02/09/18 01:27 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
I think they've got some good things going for them, such as needing gear oil for a lube as opposed to expensive, unit-specific ATF/CVT fluid. Not a lot of heat generated, nor the need for fluid coolers/heaters either.
Like said, I think with the right driver and driving conditions, DCTs could be a great thing.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: School me on the DCT [Re: andyd] #4661008
02/09/18 02:30 PM
02/09/18 02:30 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Which DCT doesn't need a special oil?
"Zed's dead baby, Zed's dead."
Re: School me on the DCT [Re: rooflessVW] #4661027
02/09/18 02:42 PM
02/09/18 02:42 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Dry clutch units should not need anything special.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: School me on the DCT [Re: KrisZ] #4661048
02/09/18 03:07 PM
02/09/18 03:07 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
And yet...
Porsche, BMW, VW, Audi, Ford, etc. all use special oils in their dual clutch gearboxes.
Re: School me on the DCT [Re: rooflessVW] #4661063
02/09/18 03:41 PM
02/09/18 03:41 PM
And yet...
I'm talking from a technical point of view, not marketing and revenue generation. If the clutches are dry, the only reason I can think of is some special and exotic materials used in synchros to cope with the computer controlled actuators. But I think it's a stretch.
Re: School me on the DCT [Re: andyd] #4661064
02/09/18 03:42 PM
02/09/18 03:42 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Most DCT fluids are MTF-type formulations with an [email protected] viscosity.
https://www.youtube.com/watch?v=lFAtc-zOKZs
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: School me on the DCT [Re: WyrTwister] #4661161
02/09/18 05:16 PM
02/09/18 05:16 PM
Danh Offline
Danh  Offline
The Escape has a conventional 6 speed automatic. DCTs are on the Focus and Fiesta.
There are DCTs and there are DCTs. The Focus/Fiesta version sold in the US is a dry-clutch unit designed for lower torque applications. This version is sold elsewhere too, but more common is a wet-clutch, high torque DCT mated to Diesel engines.
Fordís was and is a mess. First, itís a dry clutch that is inherently more challenging. Second, itís uncomfortably close to its torque capacity in the Focus. Third, Ford did an abysmal job of testing, Fourth, quality control over the gearbox and clutches was lousy. Having owned one and gone through 3 clutch packs and countless program updates over 45k, I can confidently advise people to stay away.
I now have an Acura with both wet clutches and a torque converter and itís great.
DCTs are more engaging to drive than a conventional automatic and can be more efficient. Properly designed, they can also be trouble free. But stay away from dry-clutch variants.
Re: School me on the DCT [Re: supton] #4661210
02/09/18 06:37 PM
02/09/18 06:37 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This is no longer true.
All modern auto transmissions vary pressure to the clutches depending on RPM & Load.
Under light cruise, very little hyd pressure is to the clutches.
Under heavy load and acceleration, the pressure increases to keep the clutches tight.
