Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
100 registered members (bbhero, 2015_PSD, Anduril, Astro14, Avelectro, BeerCan, 14 invisible), 2,222 guests, and 31 spiders.
Topics287,749
Posts4,933,785
Members67,850
Most Online2,967
Mar 10th, 2019
Using NiCopp for an oil filtration system line. #4660764
02/09/18 10:46 AM
02/09/18 10:46 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
I have a 1952 Chevy DeLuxe with the external add-on oil filtration system. It is mounted to the engine, and is plumbed using what appears to be 5/16" steel brake line.
One of the steel brake lines has developed a leak at a 90 degree bend. I would assume that the bend stressed the line, and some 50 years later, it has given up.
The existing lines are steel. Now, the material of choice at AAP/AZ/NAPA appears to be NiCopp, as that is what they stock.
Is there any issue with using NiCopp for an application like this? There shouldn't be any movement, as everything is mounted to the engine. The only issue would be with vibration from the engine itself.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4660767
02/09/18 10:50 AM
02/09/18 10:50 AM
USA
mk378 Offline
mk378  Offline
USA
NiCopp would work great for that. The only reason to use steel would be for antique authenticity.
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4660831
02/09/18 11:44 AM
02/09/18 11:44 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Heh heh. If you hadn't tightened up the connection at the basket hard enough to stop the persistent weep that ran down and coated the line with oil and dirt for 60 yrs or so, you wouldn't need to change it grin2
Thick oil is better grin2
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4661071
02/09/18 03:46 PM
02/09/18 03:46 PM
KS
red7404 Offline
red7404  Offline
KS
i bought some NICopp. used only a little. it works like steal. but when i clamped it with the clamping block it would crush very easy. best to be willing to wast some to learn how to make it work. it will NOT rust. be sure to double flare it like steal.
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4661099
02/09/18 04:22 PM
02/09/18 04:22 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
It has been years but there used to be premade flexible lines made up for the industrial engines that used Bypass filters instead of full flow.
2015 F150 2.7
2018 F350 6.2
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4661131
02/09/18 04:51 PM
02/09/18 04:51 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, modern hydraulic hose in its weakest form is 350 psi with push-on fittings. Just get the lines made a tractor shop and never look back smile
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4661199
02/09/18 06:26 PM
02/09/18 06:26 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
There should be no issue, they used copper tubing OE for mechanical gauges back in those days. Putting a coil in the copper line is an old school way of preventing breakage. Or find a Parker store and let them make something for you out of steel or SS.
Re: Using NiCopp for an oil filtration system line. [Re: mrsilv04] #4661401
02/09/18 10:17 PM
02/09/18 10:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I use long grease gun hoses (1/8" NPT) on those older Chevy engine oil filters.
