Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
90 registered (alcyon, AandPDan, ArrestMeRedZ, 4WD, Astro14, andyd, 9 invisible), 1483 Guests and 35 Spiders online.
65294 Members
67 Forums
285761 Topics
Page 1 of 3 1 2 3 >
#4660638 - 02/09/18 07:45 AM The percentage on a resistor...
daves66nova Offline
Loc: los angeles
I need to get 0.1 Ohm, 10%, 1 Watt. Question is, is it better to have a 5% or even 1%? I need to get 2 of these for someone to repair a board.
THIS SPACE FOR RENT, PLEASE PM ME.
#4660655 - 02/09/18 08:03 AM Re: The percentage on a resistor... [Re: daves66nova]
Trav Offline
Loc: MA, Mittelfranken.de
#4660660 - 02/09/18 08:07 AM Re: The percentage on a resistor... [Re: daves66nova]
Fitter30 Offline
Loc: Peace valley, Missouri
1% is a closer tolerance that 10% so it should be closer to .1 ohm but being such a low resistance you might not tell without out a very good meter
#4660670 - 02/09/18 08:20 AM Re: The percentage on a resistor... [Re: daves66nova]
SR5 Offline
Loc: Down Under
The percentage is the error in the resistance value, or how close it is to it's nominal value. So yes a lower % is better.
Most regular resistors are 10% from memory.
Often there is a variable resistor in the circuit to do the fine tuning, so a higher % deviation from the ideal value may not be a big issue, as it can be tuned out later. Still I have found lower % resistors are almost always better made and of better overall quality.
If I needed a 10% resistor, them I would often spend a bit more and get a 5% one.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4660672 - 02/09/18 08:24 AM Re: The percentage on a resistor... [Re: daves66nova]
Donald Offline
Loc: Upstate NY
The % is tolerance to the stated resistance. So a 1% is best.
2015 Ford F250 w/Powerstroke
#4660686 - 02/09/18 08:40 AM Re: The percentage on a resistor... [Re: daves66nova]
Quattro Pete Offline
Loc: Great Lakes
It depends on how close to 0.1 Ohm you need to be.
With a 10% tolerance, the actual resistance can be anything from 0.09 Ohm to 0.11 Ohm.
With a 1% tolerance, the actual resistance can be anything from 0.099 Ohm to 0.101 Ohm.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4660741 - 02/09/18 09:30 AM Re: The percentage on a resistor... [Re: daves66nova]
Kestas Online   content
Loc: The Motor City
If the circuit originally called for a 10% tolerance resistor, spending more for tighter tolerance would be a waste of money. It's like buying premium fuel for a vehicle that specifies regular.
Why are the resistors being replaced? Did they burn up? If you want to upgrade resistors, go higher in wattage. 2 watts would be appropriate. I restore old radios and I exclusively buy 2W metal film resistors for replacement (which happen to be 5% tolerance). They don't cost much more than 1W, and the physical size of 2W resistors is about the same size as the carbon resistors they replace.
#4660774 - 02/09/18 09:54 AM Re: The percentage on a resistor... [Re: daves66nova]
mk378 Offline
Loc: USA
In some circuits a low ohm resistor is used as a fuse. This has several implications:
* Find out why it burnt, or the new one is going to do the same thing.
* Don't increase wattage.
* Use a fusible or "flame proof" resistor.
#4660904 - 02/09/18 11:50 AM Re: The percentage on a resistor... [Re: daves66nova]
Papa Bear Offline
Loc: Leamington, ON, Canada ..... r...
Why do you need this resistor? What circuit is it in?
Why isn't the tech who is fixing the board getting the part(s)?
Is this a stereo amplifier you are working on?
2016 Dodge GC Deep Cherry
2013 SYM Wolf Classic
2011 Suzuki S40
https://www.hogsforhospice.com/
Friend of Bill W. since '89
#4660930 - 02/09/18 12:22 PM Re: The percentage on a resistor... [Re: daves66nova]
supton Online   content
Loc: NH
Lower % is better. However, get the same type, or one better. Most 1%'s film types aren't rated for surge power; they seem to drift if abused. Carbon composition or other power types will take abuse better. I'd think 5% 1W metal film of some sort, maybe surge rated.
I do most of my shopping at Digikey; I assumed thro-hole and narrowed the search donw. Link
Edit: on the off-chance it's SMT: Link
Edited by supton (02/09/18 12:24 PM)
2011 Toyota Camry, base, 2.5L/6MT, 162k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 143k, ours
1999 Toyota Camry LE, 2.2L/4AT, 183k, his
#4660934 - 02/09/18 12:24 PM Re: The percentage on a resistor... [Re: daves66nova]
Win Offline
Loc: Arkansas
Is it being used for a precise voltage drop at a given current?
I would get a 1% resistor. They're only pennies more, if that.
You need special equipment or some other techniques to accurately measure resistance that low, so get the 1% part and hope for the best.
09 Torrent 3.6 V6 M1 0/40
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 Fram 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
#4660937 - 02/09/18 12:26 PM Re: The percentage on a resistor... [Re: Win]
Loc: NH
His 1W requirement kinda points otherwise; yeah, one can do high power dividers but it's kinda rare to see that. At least I haven't come across that need.
If the circuit was properly designed and meant to be ok with 10% resistors, then I don't see a need to measure. Replace and move on.
#4660942 - 02/09/18 12:30 PM Re: The percentage on a resistor... [Re: Kestas]
Win Offline
Loc: Arkansas
Originally Posted By: Kestas
.... I restore old radios and I exclusively buy .... metal film resistors ....
They can be more inductive than carbon comp. Modern ones are pretty good, but it can still be an issue at VHF.
94 Xj12 6.0 V12
#4660943 - 02/09/18 12:30 PM Re: The percentage on a resistor... [Re: supton]
Win Offline
Loc: Arkansas
I was thinking of a meter shunt.
94 Xj12 6.0 V12
#4660945 - 02/09/18 12:32 PM Re: The percentage on a resistor... [Re: daves66nova]
Loc: NH
I could see meter, but why would it have used a 10%? I guess if there was a cal pot someplace.
Curious now what the application is.
Page 1 of 3 1 2 3 >
