Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
51 registered members (AVB, advocate, CleverUserName, boulderdentist, carlprop, 5 invisible), 843 guests, and 33 spiders.
Topics291,025
Posts4,854,640
Members66,070
Most Online3,590
Jan 24th, 2017
'97 Accord swinging overcharge #4660630
02/09/18 08:33 AM
02/09/18 08:33 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
I have a '97 Accord in the shop that will swing from 14V to 18V, back and forth, over the course of 5-8 seconds. When the voltage spikes the battery light and several other lights on the dash (SRS, ABS, all the door-open indicators) come on. After several minutes it seems to stabilize but the thing usually dies and refuses to restart before that happens. Ideas?
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660647
02/09/18 08:54 AM
02/09/18 08:54 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Sounds similar to my old Accord when the alternator was in need of replacement.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: '97 Accord swinging overcharge [Re: Char Baby] #4660648
02/09/18 08:56 AM
02/09/18 08:56 AM
wv
krismoriah72 Offline
wv
Voltage Regulator in the Alternator.
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660658
02/09/18 09:05 AM
02/09/18 09:05 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
K. I'd not yet seen one act this way, but I knew it had to have something to do with the regulator - just didn't want to throw an alternator on it (unless the VR can be replaced separate?) and it be the PCM or something giving a bad signal to the alt. - if the system even works that way. Having multiple small wires running to the alternator I wasn't going to rule out that the PCM commands it.
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660677
02/09/18 09:28 AM
02/09/18 09:28 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The regulator is replaceable but cost a fortune. It doesn't matter if the ecm is triggering it or not it shouldn't be putting out 18v, that kind of voltage can do damage. I would go with a new Bosch one from RA.
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660698
02/09/18 09:52 AM
02/09/18 09:52 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Replace the alternator before it can do more damage.
Some places have local alternator/starter shop that can get you better alternator and faster.
  • 2017 Toyota Sienna
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660711
02/09/18 10:02 AM
02/09/18 10:02 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Just as a precaution , check those little wires on the altanator for bad connection , etc. .
Wyr
God bless
Re: '97 Accord swinging overcharge [Re: Alex_V] #4660879
02/09/18 12:21 PM
02/09/18 12:21 PM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
I'd check the connections from the alternator to PDC / battery
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: '97 Accord swinging overcharge [Re: Miller88] #4661208
02/09/18 06:33 PM
02/09/18 06:33 PM
Trav Offline
Trav  Offline
For sure check all connections but back in the day in the field we use to pop the battery cable to check the alternator (it didn't work on generators and they needed + input), if it continued to run the unit was working if it died it wasn't.
Do not do this today! The point is even when the cable was removed the alternator would still regulate not spin up to 18V. I am surprised this car hasn't burned out all the bulbs in the car.
Re: '97 Accord swinging overcharge [Re: Trav] #4661628
02/10/18 08:15 AM
02/10/18 08:15 AM
sw ohio
willbur Offline
willbur  Offline
sw ohio
Disconnect alternator? My electrical system repair textbook (back in the day) said never to do this as high uncontrolled voltage would result with nothing to adsorb it. Was that book wrong? We used to do a very quick field test of alternator by holding a screwdriver to the rear bearing housing- if it was pulled in by the magnetic field, it was producing at least some output.
Re: '97 Accord swinging overcharge [Re: willbur] #4661700
02/10/18 09:54 AM
02/10/18 09:54 AM
Trav Offline
Trav  Offline
Course the book isn't wrong its a dirty way to do it but guys did it anyway, back in those days cars used mechanical regulators and nothing electronic so nothing happened for the couple of seconds it was off.
Screwdriver on the rear bearing worked also as you say to at least determine if it was working.
Re: '97 Accord swinging overcharge [Re: Alex_V] #4662952
02/11/18 01:55 PM
02/11/18 01:55 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I believe if there is a large voltage drop on the - / body part of the voltage regulator, the voltage value can rise.
Re: '97 Accord swinging overcharge [Re: JHZR2] #4662970
02/11/18 02:14 PM
02/11/18 02:14 PM
Trav Offline
Trav  Offline
It does slightly with the old mechanical regulators but I never saw 18+v, as I said for momentary removal no harm done on those systems.
Re: '97 Accord swinging overcharge [Re: Trav] #4666433
02/15/18 06:56 AM
02/15/18 06:56 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
the common denso regulator is $15 on ebay and comes with a brush set.
i changed one in the car in 10 minutes on a 99 accord.
sounds like thats what is wrong with the op's unit.
mine was not sealed right at the factory and when a rather large family of carpenter ants colonised the car the washing to get rid of them killed the reg.
btw if the ground reference is poor the reg will respond with higher output.
so check that first.but its a cheap easy fix on the car.
regulator ebay
Re: '97 Accord swinging overcharge [Re: Alex_V] #4667623
02/16/18 10:30 AM
02/16/18 10:30 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Solved. After much head banging and talking to the owner (who thought the problem had persisted since before the alternator was changed the last time with a $75 Ebay unit) and his nephew who said he thought different, I put a Napa reman on it and all was good.
Gotta say, the little car ran and drove real good for 323K.
