Originally Posted By: HondaBroMike
Originally Posted By: DirtyApe
I'm going with spec but just looking to see what's a good brand with the small turbo engine.
I got the honda 1.5 liter turbo and I use Honda full synthetic 0w-20 during my "extended break-in" and then I put in what I call the 'good stuff', none other than the mighty Idemitsu 0w-20 full synthetic. Keep in mind, the KV100 is in the mid 8 for 0w-20 oil and the HT/HS=2.6. You don't need more than that as it covers up to 5w-20. Now the 30 weights will net you KV100 in the 10 range and 2.9 HT/HS but this engine is speceed for 0w-20 so you have to give that weight. look at my signature, lighter works better and in addition, in an engine designed for it.
Wow quite a bit of info, thank you!
