Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
57 registered (4WD, Alex_V, ArrestMeRedZ, 13 invisible), 972 Guests and 68 Spiders online.
65299 Members
67 Forums
285817 Topics
#4660214 - 02/08/18 05:37 PM 08 Fusion AWD driveshaft replacement
wolfehunter Offline
Loc: Pennsylvania
So my daughter's car started making a drivetrain noise and after some research and crawling under the car and pushing on the driveshaft I believe it is a carrier bearing on the 3 piece driveshaft that can't be greased. Does anyone know if that driveshaft will slide out the rear of the car without taking down the exhaust? It looks like I might be able to get it out but before attempting it I thought I would ask here. Anyone have any pointers or experience replacing one of these? I ordered a two piece greasable axle from Detroit Axle to replace the bad one. Thanks, Scott
11 GMC Sierra 1500 100K
06 Toyota Sequoia 74K
07 Honda Accord 207K
70 Chevelle SS 112K
#4660235 - 02/08/18 06:05 PM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
tig1 Offline
Loc: Illinois
Check with You Tube and see if the fix is on there.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4660271 - 02/08/18 06:35 PM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
wolfehunter Offline
Loc: Pennsylvania
Yes, I searched YouTube for either the Fusion or Mercury Milan but no dice!
70 Chevelle SS 112K
#4660282 - 02/08/18 06:47 PM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
14Accent Offline
Loc: MN
Factory info says disconnect the flex pipe up front and dangle the exhaust for removal. You can try sneaking it out, might work might not.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4660420 - 02/08/18 09:09 PM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
wolfehunter Offline
Loc: Pennsylvania
Thanks for the tip.
70 Chevelle SS 112K
#4662950 - 02/11/18 12:53 PM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
wolfehunter Offline
Loc: Pennsylvania
Unhooked driver's side rubber hanger on exhaust and removed/installed the driveshaft by having my daughter push the exhaust towards passenger side and sliding the driveshaft out towards the front of the car. Took us about 90 minutes from start to finish. She was a little nervous laying under the car and trusting the 4 jack stands but she braved it out!
70 Chevelle SS 112K
#4663770 - 02/12/18 10:47 AM Re: 08 Fusion AWD driveshaft replacement [Re: wolfehunter]
andyd Offline
Loc: Marshfield , MA
Next time you need to move the exhaust, wrap a piece of clothesline, etc, around it, Pull exhaust aside and close the rope in the door. OTOH, teaching car maintenance awareness to a child is a good idea too. Good parenting grin2
Thick oil is better grin2
