Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
129 registered members (AndyB, 2010Civic, agpatel, ABerns, 77GrandPrix, 11 invisible), 2,030 guests, and 67 spiders.
Topics286,429
Posts4,908,089
Members67,622
Most Online2,967
Mar 10th, 2019
Lithium-ion battery maintenance #4659932
02/08/18 12:02 PM
02/08/18 12:02 PM
Washington State (East)
Blaze Offline OP
Blaze  Offline OP
I'm going to get a new lithium-ion to replace the original lead acid in my Yamahs WR. Do folks use a battery tender on these? If so what brands/types are recommended? thanks
Re: Lithium-ion battery maintenance [Re: Blaze] #4659955
02/08/18 12:33 PM
02/08/18 12:33 PM
Canada
JimmyD Offline
JimmyD  Offline
Canada
You need a specific type of charger for Lithium batteries.
Optimate make a couple variants but AFAIK don't make a charger that works with both LiFe batteries and lead acid; Battery Tender makes one that is switchable between the two types.
Personally, I find Battery Tenders cheap in construction and prefer Optimate products, but they're typically more expensive to buy.
Optimate 0.8A Lithium Charger (Canadian pricing
Battery Tender switchable Charger
2014 Mazda 3 2.0L 6MT
Re: Lithium-ion battery maintenance [Re: Blaze] #4660053
02/08/18 03:30 PM
02/08/18 03:30 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
The Ballistic batteries also have available a cell balancing charger that hooks to a dedicated connector. It allows the battery to be properly maintained over long periods of time.
It's convenient as it does not use the terminals for connection.
Re: Lithium-ion battery maintenance [Re: Blaze] #4660161
02/08/18 05:57 PM
02/08/18 05:57 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Yes with LiPo or similar you need a good balance charger and usually have the balance leads like pictured. Sometimes they charge through that post alos, if its low amperage, but more amperage would require a typical positive negative connection as well.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Lithium-ion battery maintenance [Re: Blaze] #4660268
02/08/18 07:34 PM
02/08/18 07:34 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Lithium batteries that are abused such as being overcharged can explode with an almost unbelievable amount of energy (think plastic explosive or dynamite, seriously!). Fortunately most lithium batteries have builtin protection that prevents them from allowing the abuse that would cause them to explode. Often the protection circuit is a one time fail safe device that renders the battery unusable once it is tripped.
So, don't cheap out on the charger for a lithium battery. It is very important to get it right the first time.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Lithium-ion battery maintenance [Re: Blaze] #4660290
02/08/18 07:54 PM
02/08/18 07:54 PM
Idaho
SubLGT Offline
SubLGT  Offline
Idaho
Lead acid batteries have longest service life when kept at 100% state of charge. Lithium ion batteries are the opposite. They will have a shorter life if constantly kept near 100% SOC.
Re: Lithium-ion battery maintenance [Re: JimPghPA] #4660327
02/08/18 08:33 PM
02/08/18 08:33 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
No, they don't explode with much force at all except very rare cases with specific circumstances such as an external source of fire causing very rapid heating, not from the battery itself failing. They have vents which prevent pressure buildup to far below the level of a plastic explosive or dynamite, it's not even in the same ballpark.
Certain lithium chemistries will turn into a fire ball, but explosion is very rare outside of sensationalists using the word "explode" inappropriately. Granted, you don't want a fireball either, but it's decidedly less deadly than riding around with dynamite under your seat.
Re: Lithium-ion battery maintenance [Re: Blaze] #4660337
02/08/18 08:42 PM
02/08/18 08:42 PM
Blaze Offline OP
Blaze  Offline OP
thanks for the reply's learned a few things I didn't know. i like that Ballistic battery!
Re: Lithium-ion battery maintenance [Re: Dave9] #4660408
02/08/18 09:58 PM
02/08/18 09:58 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
It is rather common to see the vents release at inconsistent pressures, or for crimped cells to eject their entire contents. Cells venting without fire can create explosive mixtures.
It's dependent on the type of abuse they encounter.
Re: Lithium-ion battery maintenance [Re: Blaze] #4660488
02/08/18 11:44 PM
02/08/18 11:44 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I hook up a tender every 4 months or so, shows 100% within minutes. Lifepos have a super slow self discharge rate, they can safely sit for months and be just fine. I use a Duracell 0.8 amp, cheapie fro batteries + on my Shorai.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Lithium-ion battery maintenance [Re: Blaze] #4660490
02/08/18 11:45 PM
02/08/18 11:45 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
It's rare, but Lithium chemistry batteries can be far more dangerous than lead-acid. As we speak Hewlett-Packard (4 January), Lenovo (6 February) and today (8 February) Fujitsu are recalling laptops with defective, potentially dangerous batteries.
At least two aircraft have burned to the ground, and there have been fatalities, due to lithium batteries in cargo (both were cargo aircraft, the most famous one being a FedEx plane landing in Tokyo).
There is a circuit inside Lithium chemistry batteries that monitors the resident charge level (volts). When that charge falls below a specific point, the battery can become unstable and potentially dangerous. Lithium burns at very high temperatures (4,000F and higher) so it quickly starts large fire emergencies. The circuit is supposed to kill the battery (make it un-usable) if the voltage falls below the trip point.
Two issues worth noting.
One, cheap Asian batteries often ship with substandard or completely missing safety circuitry. That is the reason for virtually all battery recalls (although it's typically not the result of cheap sourcing but instead errors in manufacturing at a reliable plant). That is also why you can buy a replacement battery for your phone or computer for one third the cost of OEM. Every single instance of "exploding [name your phone] so far is due to third party replacement batteries.
You might be buying a fire hazard to save a few bucks. There are reputable third-party battery suppliers, I strongly suggest everyone take advantage of them and refrain from choosing the very cheapest options from dubious sources (which, unfortunately, now includes Amazon).
Two, the electronics inside the battery have *nothing to do with charging*. All the safety with charging Lithium batteries is in the charger. Don't scrimp there either.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Lithium-ion battery maintenance [Re: JimmyD] #4660522
02/09/18 01:09 AM
02/09/18 01:09 AM
SF Bay Area
y_p_w Online content
y_p_w  Online Content
SF Bay Area
Very, very specific. There were a lot of things learned early with lithium rechargeable battery technology, like overcharging causes fires (like the Sony fire in 1995), so don't actually get to that point. Or deep discharge and it will never come out of it. Most lithium rechargeable batteries are designed around stopping well shy of the maximum theoretical charge, which boosts longevity and safety.
You can grab almost any reasonable universal "smart charger", place it on a suitable lead-acid battery of any reasonable size, and it should be safe to charge it. Lithium rechargeable batteries should have some sort of smart battery system on a circuit within the battery housing, that talks to the battery management of the charging circuits. There is no such thing as a safe universal lithium battery charger. Chargers are typically built into the devices and almost always do better with OEM batteries. They need to build up a proper estimate of the capacity to help with charging, rather than doing some sort of universal charging algorithm.
https://en.wikipedia.org/wiki/Smart_Battery_System
At best, a lousy lithium rechargeable battery might work poorly because it fudges the specs to kind of work. I've been spending time on a computer message board where one guy is asking why his $27 aftermarket battery (OEM is over $100) is resulting in unplanned shutdowns when the computer thinks it's at 70% charge. We all know what happens when lithium batteries aren't properly charged with precision devices. Hoverboards catch on fire and e-cigs blow up in peoples' faces.
Re: Lithium-ion battery maintenance [Re: Johnny2Bad] #4660523
02/09/18 01:25 AM
02/09/18 01:25 AM
SF Bay Area
SF Bay Area
A well-designed lithium rechargeable battery should at least store basic statitics useful for properly estimating the state of charge and the remaining capacity. You don't really see that level of detail with any other kind of battery chemistry. And sometimes it can go nuts. I had a laptop battery suffer from an unplanned shutdown on battery power. I think it just sort of shut down to prevent thermal damage. When I started the computer up again, I could check the battery diagnostics and it was reporting negative maximum battery capacity. It was weird too because I kept on using it until it was reporting it was normal again, then reporting negative, then it started swelling. Something like this:
Samsung had serious issues with batteries that were made by a reliable supplier, as well as their own battery division. However, wasn't that due to bad thermal design and not the quality of the battery?
Re: Lithium-ion battery maintenance [Re: Blaze] #4660537
02/09/18 02:02 AM
02/09/18 02:02 AM
CA
shoutscout Offline
shoutscout  Offline
CA
[b][/b]www.batterystuff.com
ask these guys about chargers...free shipping and no tax from oregan....hit em up I have been
very pleased with their customer service and knowledge of product...
Re: Lithium-ion battery maintenance [Re: Blaze] #4660614
02/09/18 08:05 AM
02/09/18 08:05 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
You never want to use a battery maintainer on a lithium battery, not needed and will shorten its life.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
