Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
98 registered members (4WD, -SyN-, AndyB, 2010Civic, 12 invisible), 1,954 guests, and 36 spiders.
Topics290,939
Posts4,852,882
Members66,062
Most Online3,590
Jan 24th, 2017
Q8 T750 15W40 #4659823
02/08/18 09:50 AM
02/08/18 09:50 AM
Reunion Island
Superflan Offline OP
Reunion Island
Hi,
I just did a oil and filter change on my small Cargo van Kangoo.
The last change was in January 2015, with Castrol Magnatec.
This time I used this oil:
Q8 T 750 15W-40
Description
Super High Performance Diesel Engine Lubricant designed for lubrication of low emission Euro IV & Euro V engines.
Application
• In all high performance four stroke diesel engines operating on low sulphur diesel fuel (<0.05 % mass) and under severe heavy duty conditions. Extended oil drain intervals as indicated by the OEM for high quality diesel engine oils can be applied.
• The diesel engines may be normally aspirated, turbocharged or supercharged, with or without intercooling and fitted in commercial vehicles or off-highway equipment.
• Suitable for application in passenger cars with gasoline or diesel engines.
Specifications
ACEA E7
API CI-4/SL/CF
Global DHD-1
MAN M3275
MB Approval 228.3
Volvo VDS-3
MTU Type 2
Renault VI RLD & RLD-2
Deutz DQC III-10
Cummins CES 20071, -72, -76, -77, recommended for 20078 Caterpillar ECF-1 & ECF-2
Mack EO-N
Exceeds requirements of DAF, IVECO and Scania
Benefits
• Excellent protection against bore polishing and cam wear
• Offers prolonged oil drain intervals and reduces maintenance costs
• Protects engine against corrosive wear in off-the-road applications
• Provides quick lubrication after cold starting thus limiting engine wear
• Prevents engine fouling due to combustion soot
• Performance quality allows wide application from cars to trucks
• Universal engine oil suitable for passenger cars, trucks and off-road applications
What you guys think about this oil?
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealer’s overfilled, 16000 Km
Re: Q8 T750 15W40 [Re: Superflan] #4659860
02/08/18 10:45 AM
02/08/18 10:45 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
If your dCi has DPF it will became clogged soon...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Q8 T750 15W40 [Re: Kamele0N] #4659881
02/08/18 11:14 AM
02/08/18 11:14 AM
Reunion Island
Reunion Island
No DPF. EGR and DOC (if still fitted)
Re: Q8 T750 15W40 [Re: Superflan] #4659883
02/08/18 11:15 AM
02/08/18 11:15 AM
Reunion Island
Reunion Island
But for another purpose, teach me about DPF poisoning in low-to-none oil consumption engine ?
Re: Q8 T750 15W40 [Re: Superflan] #4660525
02/09/18 01:31 AM
02/09/18 01:31 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
It looks fine, but the SA is way high in comparison to a CJ-4 or CK-4, much less a C3 oil, and I think that's the only thing that was really being pointed out.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Q8 T750 15W40 [Re: Superflan] #4660586
02/09/18 06:58 AM
02/09/18 06:58 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Then this E7 CI4 would be a good selection.
Btw, what's your intended OCI and diesel sulphur levels ?
Re: Q8 T750 15W40 [Re: Garak] #4660587
02/09/18 06:59 AM
02/09/18 06:59 AM
Reunion Island
Reunion Island
Could it cause scoring or ring sticking ?
Re: Q8 T750 15W40 [Re: Superflan] #4661332
02/09/18 09:10 PM
02/09/18 09:10 PM
Garak Offline
Garak  Offline
I shouldn't think so. It's not like it's over the top like a marine lube. wink Over the years, such HDEOs have been used even in gasoline engines. It's not terribly far off in SA from an A3/B4.
Re: Q8 T750 15W40 [Re: Garak] #4669325
02/18/18 08:25 AM
02/18/18 08:25 AM
Reunion Island
Reunion Island
Garak, please teach me what's wrong with using HDEO in gasoline engines where ULSF is used ?
Re: Q8 T750 15W40 [Re: Superflan] #4672625
02/21/18 01:33 AM
02/21/18 01:33 AM
Garak Offline
Garak  Offline
There is nothing wrong with it, as far as I can see. Now, if you're talking about a C3 oil in a gasoline engine, one would be able to maximize the OCIs if the fuel were ULSG. With the opposite, I see no problems running an E7, E9 or an E6, E7, E9 type lubricant with ULSG. In fact, I probably am doing that "on occasion" as it is already, unwittingly. Further, if ULSG came into our gas stations magically and unerringly tomorrow, my lube choice would not change; I am using an HDEO in a gasoline engine.
