More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
105 registered members (BeerCan, Astro14, beanoil, Billbert, 2004tdigls, 11 invisible), 1,760 guests, and 38 spiders.
Topics290,936
Posts4,852,740
Members66,060
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
conventional oil? #4659754
02/08/18 08:28 AM
02/08/18 08:28 AM
ogdensburg new york
ernied Offline OP
ernied  Offline OP
ogdensburg new york
does anyone use conventional oil in the Hyundai 2.4 engine.
I have been using synthetic and wondering if iam wasting my money since it doesn't call for it.
2015 Hyundai sonata.
2015 Hyundai santafe sport
Re: conventional oil? [Re: ernied] #4659763
02/08/18 08:56 AM
02/08/18 08:56 AM
Florida
Artem Offline
Artem  Offline
Florida
Well... if you could "get away" with using the cheap and standard conventional Lube without any negative side effects, and that is what the engine manufacturer recommends you use in the car, then what's stopping you?
Having said that, I honestly don't understand why anyone would even use the cheap stuff when you can easily find synthetic oil on sale for $3-4 a quart and have peace of mind that you've got Synthetic oil in the engine.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: conventional oil? [Re: ernied] #4659785
02/08/18 09:17 AM
02/08/18 09:17 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
Run it conventional with confidence if you want. As long as your running MFG. spec oil; those engines are bullet proof as long as your changing the oil and filter.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
Rotella T6 5W30 & Wix (91K)
2000 Ram 4X4 5.2L (93K) PYB & FU
Re: conventional oil? [Re: ernied] #4659790
02/08/18 09:25 AM
02/08/18 09:25 AM
MA USA
andrewp1998 Offline
andrewp1998  Offline
MA USA
you can get castrol edge on sale at wallyworld for 20 bucks sometime, mobil with rebate is cheaper!
2001 Honda civic HX vtecE- 5 spd,232k+
Re: conventional oil? [Re: ernied] #4659821
02/08/18 09:48 AM
02/08/18 09:48 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
It may help with ring sticking if the premium cost product has less vm and a more stable base, OTW there is no conventional ILSAC oils and most "synthetic" ARE NOT.
I tend to find very good oils amoungst the "synthetic" offerings that let my engine perform better.
Not all premium oils are worth the added cost.
QSGB and motorcraft are decent conventionals.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: conventional oil? [Re: ernied] #4659825
02/08/18 09:52 AM
02/08/18 09:52 AM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I would use whatever oil you can get a really good deal on. The engine you have usually only blows up from manufacturing defects or lack of maintenance. The type of oil you use doesn't matter, only the fact that you change it on time and keep receipts for the warranty.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: conventional oil? [Re: ARCOgraphite] #4659826
02/08/18 09:52 AM
02/08/18 09:52 AM
Texas
Dallas69 Offline
Dallas69  Offline
Texas
MC is a blend
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: conventional oil? [Re: ernied] #4659837
02/08/18 10:12 AM
02/08/18 10:12 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
My sisters '10 Santa Fe with the 2.4 has gotten to 150,000 miles using conventional oil from an oil change shop on 7500-10,000 mile intervals.
It only recently started getting synthetic since I started changing the oil in it.
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: conventional oil? [Re: ernied] #4659866
02/08/18 10:56 AM
02/08/18 10:56 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
In NY with the cold winters and hot humid summers, I'd prolly go syn (they're all blends). Maybe SuperTech laugh
Re: conventional oil? [Re: ernied] #4659869
02/08/18 10:59 AM
02/08/18 10:59 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Disregard the "why would anyone run cheap stuff" crowd when the mfcr has confidence that their recommendation of API-SM/ILSAC GF-4 will properly lubricate the engine. In fact, it has done so without issue since 2011 with this platform, having one hiccup, a build issue at one of the assembly plants for certain years. It is absolutely perfectly fine to run Conventional oil in the 2.4. As a matter of fact, my Sonata will be getting a steady dose of dino here-on-out.
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: conventional oil? [Re: ernied] #4659894
02/08/18 11:28 AM
02/08/18 11:28 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
You are not wasting your money. It's only a few cents per week. Now if your rides are not worth a few cents per week, then yes .
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: conventional oil? [Re: ernied] #4659933
02/08/18 12:03 PM
02/08/18 12:03 PM
West Central , FL
johnD2 Offline
johnD2  Offline
West Central , FL
My Mother has 150k on her 2.4 Hyundai.. Nothing but valvoline white bottle every 4,000 miles , still runs like brand new.
2000 Silverado Short Wheelbase 4.8 L 4x4
Wix 51522 / Mobil 1 HM 10w40
2016 F150 crew cab 5.0 2WD
Wix 57502 / PP 5W20
Re: conventional oil? [Re: johnD2] #4659942
02/08/18 12:14 PM
02/08/18 12:14 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
There ya go. Nothing wrong with VWB, PYB, Havoline, Castrol etc etc...
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: conventional oil? [Re: ernied] #4659959
02/08/18 12:36 PM
02/08/18 12:36 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Re: conventional oil? [Re: bbhero] #4659961
02/08/18 12:39 PM
02/08/18 12:39 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
approved
Page 1 of 3 1 2 3
