Originally Posted By: BlueOvalFitter
Originally Posted By: Spector
I was at Toyota dealer yesterday and noted the 0W16 on shelf. The rep stated that the new Camry spec is the 0W16. I inquired if the engine had changed or just a lower viscosity oil for mileage. He said it was a totally new engine design but could not state whether the XW20 weight would be acceptable. I did not see an owner's manual to see any options.
They had their 0W20 brand of synthetic on sale, 4.99 a quart, not bad for a dealer price.
We did discuss that the 0W16 may make sense in Canada but for TN, the climate is pretty moderate and hot summers so the old discussion of a 0W16 holding up yielding no new thoughts. So, assuming Toyota tested the oil enough to be comfortable in all climates.
The employees had no idea who developed/refined the oil for Toyota and nothing on the bottles either,
IIRC I read somewhere they are using different bearings, perhaps other parts were changed as well. It was designed to run on the "thinner oil."
I would not chance that oil in a engine that wasn't designed with that grade of oil in mind. The risk vs. reward doesn't make any sense at all to me.
I would have to agree with you on this. But, I wonder if someone HAS tried it and the results were not so good?
This is Bitog, if someone hasn't tried it someone will. Stay tuned!!!!
