Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
116 registered members (853okg, ad_infinitum, 2012AccentSE, addyguy, aircooled, 15 invisible), 2,412 guests, and 60 spiders.
Topics286,023
Posts4,900,978
Members67,549
Most Online2,967
Mar 10th, 2019
Dual air filter - removing one of the air filters #4659600
02/07/18 11:29 PM
02/07/18 11:29 PM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
We have a 2014 Hyundai Tuscon 2.4 L DI engine
The car has a dual air filter (pzev - partial zero emission stuff ...)
i can access one of the air filters but there is another air filter on top of the other filter and is glued in to the top of the plastic canister.
was wondering if i can take it off (break off the little plastic things holding it in) and remove the second air filter.
i was told it is for zero emission and many cars (like all our other cars) don't have the second air filter!
basically i wanted to see what is on top of the 2nd air filter, for example oil from pcv and crankcase, etc. but this second air filter does not allow access. who knows it may even be nasty and dirty on top and blocking the air flow but I can never get to it.
do you have any experience with dual air filter and pros and cons of removing it.
Thanks
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659604
02/07/18 11:45 PM
02/07/18 11:45 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
I read the title before clicking and thought "It's gonna be about a Hyundai". [censored] I'm good.
My car has it too. I think the Hyundai engineers are smarter than me, so I'm not going to mess with it.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Dual air filter - removing one of the air filters [Re: Nick1994] #4659729
02/08/18 07:55 AM
02/08/18 07:55 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
To me the OP was a little lacking in description.
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659760
02/08/18 08:48 AM
02/08/18 08:48 AM
socal
barkingspider Offline
socal
My daughter’s Camry had something similar. I broke the plastic tabs and removed it over 2 years ago. Car runs fine
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659772
02/08/18 09:07 AM
02/08/18 09:07 AM
NH
supton Offline
supton  Offline
NH
I thought dual air filters was a big truck or off road equipment thing. A pre-filter to get the big stuff, like dust or whatever might be floating in the air. The real filter is downstream. Reason being, the pre-filter can be "less good" because any filter would just plug up; so make it cheaper and/or easier to clean/replace.
not sure why they'd need a better air filter on a PZEV? I mean, clean air is clean air. Unless if residue dust could be turned into PM? thus meaning they need all the more filtration?
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659818
02/08/18 09:45 AM
02/08/18 09:45 AM
Chicago,IL,USA
pandus13 Online content
pandus13  Online Content
Chicago,IL,USA
OP,
Maybe register to the hyundai forums and post the question there?
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659900
02/08/18 11:32 AM
02/08/18 11:32 AM
WI
BurrWinder Offline
BurrWinder  Offline
WI
That's likely not a "filter".. it is most likely a carbon Adsorber - ( yes, I spelled that correctly ) It is used to absorb fuel vapors that exist in the air filter housing ( after engine is shut off ) and keep them from floating away, causing emission issues. That is why it's not removable, "sposta be in there" and it isn't normally required to be replaced in the normal life of the vehicle. This usually requires filter housing replacement, if needed, to replace it - Not usually a need unless damaged. 1st filter is the filter, this part exists as described and not for filtering, technically. Other vehicles, such as some Trailblazers and others use this design, as well. Works just like a carbon canister, but "open faced" carbon to solve another problem. Vapors are drawn off in normal use anytime engine is running.
BurrWinder
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4659989
02/08/18 01:39 PM
02/08/18 01:39 PM
Wash, DC
circuitsmith Offline
Wash, DC
The second air filter has activated charcoal to catch any wisp of raw gas that makes its way up the intake manifold when the engine is stopped.
Then, when the engine is running, fresh air coming in (somewhat) clears the charcoal of gas.
My '06 Matrix had one too...until I yanked it out.
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Dual air filter - removing one of the air filters [Re: OilUzer] #4660301
02/08/18 08:08 PM
02/08/18 08:08 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
I kept mine in my Tacoma. Doesn’t hurt anything.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Dual air filter - removing one of the air filters [Re: BurrWinder] #4660458
02/08/18 10:54 PM
02/08/18 10:54 PM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
when you open/unclip the air filter box/housing, There is a removable air filter laying down like most cars ...
However in the air filter cover (the part you unclip to access the air filter) you typically (as in all other cars I currently own from 1997 to 2016) see a hose going from air filter cap to intake. in this car I see another filter glued in there (i.e. not removable unless I break a few pins).
BurrWinder
Thanks for the replies everyone, it make sense for it to be a carbon filter to prevent fuel/vapors from exiting when the car is shut off.
Having said that, sometimes if you have issues with the pcv or vacuum you may find oil film on top of the air filter.
With this car I cannot check for that unless I break the thing and remove the second air filter (it may? affect the warranty if I ever end up in dealership). I have some issues with oil film near oil cap and pcv (I have a post under oil forum) and was going to check the air filer and see if I can find anything wrong. I will edit and add the link to my other post.
edit:
Oil Film on engine cover
