Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
117 registered members (928, andyd, Anthony, 53' Stude, Al, 15 invisible), 1,854 guests, and 38 spiders.
Topics294,998
Posts4,925,703
Members66,664
Most Online2,553
Oct 27th, 2018
2006 Grand Caravan no electrical power #4659383
02/07/18 06:40 PM
02/07/18 06:40 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
Hi Everyone,
Just recently my 2006 Grand Caravan (SXT with 3.8 liter engine) would not start. All electrical quit as nothing worked (dash, dome lights, nothing). I cycled the key a few times and power came back and it started. I was hoping that was just a fluke. Today it did it again... fortunately I was home.
I cycled the key a few times but this time no change. I tried my wife's keys thinking maybe my chipped key was bad. No difference. Since it is 100% dead, I checked online for where the fuse-able link is. It appears the newer Caravans do not have fuse-able links.
According to my cheap electrical tester the battery voltage was 12.x volts. A little low, but even with a charger on it the van is still dead.
Anyone have this happen? Any ideas of what I should check?
TIA,
Brad
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: 2006 Grand Caravan no electrical power [Re: DeafBrad] #4659393
02/07/18 06:45 PM
02/07/18 06:45 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I'd check that wire that goes from the negative on the battery to the frame and all the battery connections.
Though, not sure why you're suspecting the key when the lights are not working and they're not dependent on the key.
Everything is dead? Headlights and horn?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: 2006 Grand Caravan no electrical power [Re: Leo99] #4659407
02/07/18 06:58 PM
02/07/18 06:58 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
The reason I checked the key is it has the chipped key, and I was thinking maybe the van has anti-theft and it cut power due to not recognizing my key. It was worth a try.
Everything is dead just as if it had no battery in it. I will check the frame ground. The terminals looked fine with a visual inspection but I will remove the cables and clean them.
Geo XFI 50+ mpg
Re: 2006 Grand Caravan no electrical power [Re: DeafBrad] #4659454
02/07/18 07:50 PM
02/07/18 07:50 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
I fixed it. The cables on the battery were good, but then I noticed a previous owner replaced the negative battery terminal. They used the wrong terminal so the contact with the battery was minimal. I cleaned it and it started right up. Some time soon I will need to re-do that terminal.
Thanks to Leo99's suggestion, I was in the process of getting to the ground and discovered the battery terminal problem.
Geo XFI 50+ mpg
Re: 2006 Grand Caravan no electrical power [Re: DeafBrad] #4659855
02/08/18 09:32 AM
02/08/18 09:32 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
It's a great feeling to fix it yourself and especially when it's a simple fix.
