First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
47 registered members (alarmguy, AndyB, 87sammy, 77GrandPrix, 2015_PSD, 2013ecof150, 6 invisible), 810 guests, and 31 spiders.
Topics290,968
Posts4,853,530
Members66,063
Most Online3,590
Jan 24th, 2017
Grease to run won't stay primed? #4659284
02/07/18 05:58 PM
02/07/18 05:58 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I have to pull the lever in and out on the bottom of the gun a few times in between pumps. What's up with that?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659286
02/07/18 06:02 PM
02/07/18 06:02 PM
Houston, Texas
Houston, Texas
AutoZone warranteed the first one and this one is doing the same thing. Only today I figured out that pulling the lever helps prime it. Although last I checked you shouldn't have to do that
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659303
02/07/18 06:20 PM
02/07/18 06:20 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Grease is probably too viscous to prime. Not all NLGI 2 greases have the same consistency and you might try a different grease. I have always had the same nuisance problems with grease guns.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659330
02/07/18 06:44 PM
02/07/18 06:44 PM
Houston, Texas
Houston, Texas
Maybe that's it. Maybe I'll just buy a fresh tube.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659334
02/07/18 06:49 PM
02/07/18 06:49 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Are you opening the bleeder on top?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659337
02/07/18 06:53 PM
02/07/18 06:53 PM
Houston, Texas
Houston, Texas
Yeah.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659367
02/07/18 07:24 PM
02/07/18 07:24 PM
Houston, Texas
Houston, Texas
It used to be very liquid and leak out the bottom.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659417
02/07/18 08:07 PM
02/07/18 08:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You have an air bubble.
Pull the pump handle open (the little pressure piston) and thump the grease gun UPSIDE DOWN on a wooden block to push the huge slug of grease towards the pump head.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659552
02/07/18 10:25 PM
02/07/18 10:25 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Here's a nifty video on how to bleed a grease gun.
https://www.youtube.com/watch?v=eQyd6XrAo4w
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Grease to run won't stay primed? [Re: tig1] #4659576
02/07/18 11:02 PM
02/07/18 11:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Nice!
I can't say it's ever been that easy for me... I always have to thump it a few times.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659591
02/07/18 11:16 PM
02/07/18 11:16 PM
Houston, Texas
Houston, Texas
A trick I've found is to squeeze the handle she. You push the rod back in. Instantly primed, but this one won't do it.
Re: Grease to run won't stay primed? [Re: motor_oil_madman] #4659593
02/07/18 11:18 PM
02/07/18 11:18 PM
Houston, Texas
Houston, Texas
I'll try what the video shows though.
