Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
21 registered members (FordCapriDriver, Ablebody, Bailes1992, ArrestMeRedZ, BlakeB, 4 invisible), 880 guests, and 43 spiders.
Topics290,698
Posts4,848,443
Members66,021
Most Online3,590
Jan 24th, 2017
cause of the white mung on the batt holdown clamp? #4659106
02/07/18 02:35 PM
02/07/18 02:35 PM
Coastal South Carolina
edwardh1 Offline OP
edwardh1  Offline OP
what causes it? batt terminals have the "fuzzy" felt washers on them, no corosion on them and no corrosion on the terminals either,
but the battery hold down clamp that runs across the battery top, where it touches the edge of the top of the battery has the white mung.
where is that coming from?
Thanks.
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659124
02/07/18 02:56 PM
02/07/18 02:56 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Acid venting
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659125
02/07/18 02:56 PM
02/07/18 02:56 PM
Near Mobile
ffhdriver Offline
ffhdriver  Offline
Near Mobile
Acid fumes leak from battery or battery cap vents.
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659146
02/07/18 03:10 PM
02/07/18 03:10 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
take it off, clean with baking soda, then sand and re-coat with liquid tape or PlasticCoat
2015 Ford F250 w/Powerstroke
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659193
02/07/18 04:04 PM
02/07/18 04:04 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Yep, specifically hydrogen and oxygen venting form the cells, corroding metals that it wafts over
Re: cause of the white mung on the batt holdown clamp? [Re: PeterPolyol] #4659227
02/07/18 04:51 PM
02/07/18 04:51 PM
New England
gathermewool Offline
New England
I don't know if it helps, but I've begun applying wax to the hold-down bar and applying anti-seize to the threads. I'm hoping this prevents the mess of rust I usually end up with for decade-old vehiles.
I don't think it's either of those. It's the acid moisture that's carried with the venting gas.
What voltage is your charging system putting out?
'14 Forester XT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy 2.5i (OEM Stage -7)
Edge 0W-20 + FU filter
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659274
02/07/18 05:36 PM
02/07/18 05:36 PM
edwardh1 Offline OP
edwardh1  Offline OP
DONT KNOW, 3 1/2 YR OLD max wal mart battery, car starts well
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659329
02/07/18 06:42 PM
02/07/18 06:42 PM
New England
New England
WHY ARE YOU YELLING!? crackmeup
Re: cause of the white mung on the batt holdown clamp? [Re: gathermewool] #4659338
02/07/18 06:53 PM
02/07/18 06:53 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Right neither hydrogen nor oxygen gas is corrosive. Explosive yes. Its sulfuric acid fumes. Check the charging system.
I remember in the 1950s my Dad would bend a spring or something in the voltage regulator for the engine's generator to adjust the voltage. Before alternators. By the time I was old enough to really understand the workings of an engine they had alternators.
Re: cause of the white mung on the batt holdown clamp? [Re: edwardh1] #4659484
02/07/18 09:20 PM
02/07/18 09:20 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Like somebody else said, it's caused by venting/leaking battery acid. Clean with baking soda, and, if you want to go the extra mile, sand the corrosion off. Then coat your hold-down bracket and cable ends with Vaseline or some dielectric grease. That'll prevent it happening again.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 198K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
