Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
80 registered members (Al, 77GrandPrix, 65convertible, 53' Stude, 92saturnsl2, A310, 9 invisible), 1,760 guests, and 41 spiders.
Topics290,837
Posts4,851,206
Members66,040
Most Online3,590
Jan 24th, 2017
2002 Impala 3.4 engine #4659024
02/07/18 01:32 PM
02/07/18 01:32 PM
North Carolina, USA
thomasew Offline OP
thomasew  Offline OP
North Carolina, USA
I have a Chev. Impala, 3.4 engine with 120K miles. When I start it up I get a lot of noises, but after a couple of minutes you can't hear it run if you close the hood. Still gets 25 mpg on a road trip. I want to change the oil and am thinking about Pennzoil HM, but I don't think it is a blended oil. This motor has had oil changes around 4k or 5k its entire life. Should I just use the regular Pennzoil or the HM, or the Platinum?
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659043
02/07/18 01:49 PM
02/07/18 01:49 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
I would use HM and do 5k changes.
2002 Silverado 5.3 0w-20 AMSOIL
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659065
02/07/18 02:01 PM
02/07/18 02:01 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
The noise is normal in these 3.4L engines. It's the same story in my 2005 Impala with the 3.4L engine. Run whatever you desire and 5k intervals is fine. Really, depending on your driving style, you probably could extend the intervals out as well.
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659097
02/07/18 02:30 PM
02/07/18 02:30 PM
TX-Texas
mctmatt Offline
mctmatt  Offline
TX-Texas
Would a heavier weight oil be of any benefit? Might want to go to a 10W-30.
Re: 2002 Impala 3.4 engine [Re: mctmatt] #4659111
02/07/18 02:38 PM
02/07/18 02:38 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
I would use PYB and put the extra money you save into a decent filter, wix/gold or TG.
89 GMC Sierra T5 10w30/Wix
08 Lucerne CX NAPA Blend 5w30/Napa Gold
18 Toro Super Recycler T5 10w30
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659112
02/07/18 02:38 PM
02/07/18 02:38 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
A heavier oil won't be of any benefit really. It's just a natural occurrence in this engine. FWIW, I have ROTELLA T6 5W-30 in it and that noise is still there, as it's been for the last 3 years I have owned that car.
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659186
02/07/18 03:57 PM
02/07/18 03:57 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Yep, the clackety-clackety piston slap noise seems par for the course on the Chevy V6 on cold start up. IDK about the 3400 and prior versions, but GM brilliantly installed under-piston oil sprayers on just 2 out of the 6 pistons for whatever reason in the last version of that engine series, the LX9. I'm thinking the roots style oil pump can't support all 6 sprayers....
So yeah, it's normal.... "GM normal"
Re: 2002 Impala 3.4 engine [Re: PeterPolyol] #4659354
02/07/18 07:09 PM
02/07/18 07:09 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It has 3 Nozzles.....Each oils 2 pistons. No need for 6 separate ones on a 60 degree engine as the banks are so close to each other.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659418
02/07/18 08:09 PM
02/07/18 08:09 PM
Saskatchewan, Canada
pitzel Offline
pitzel  Offline
I have basically the same engine, a 60-degree GM V6, 3.1L. Last oil change I performed on it was 90k km's ago (56k miles) / 10 years. Had the oil pan off 2 years ago and everything was nice and clean. Esso XD-3 0W-30 synthetic.
So run long drains in that sort of engine with confidence, and of course, keep an eye on coolant leaks.
Change your thinking...not your oil!
Re: 2002 Impala 3.4 engine [Re: clinebarger] #4659556
02/07/18 10:30 PM
02/07/18 10:30 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Interesting. Not sure about the other 3x00 engines, but the LX9 3500 specifically has only 2 sprayers- it's actually a one double-ended sprayer serving Cyl 5/6 only (the rest of them are not simply just out of frame;)) Never seen this in any other engine before... it's weird
But if the noise is common across all 60 degree'ers then it's probably not the odd sprayer config
Re: 2002 Impala 3.4 engine [Re: thomasew] #4659853
02/08/18 10:28 AM
02/08/18 10:28 AM
Frozen, Canada
JHerriot Offline
JHerriot  Offline
Frozen, Canada
I'm at 160k miles in my Alero with the 3.4 and its run lube shop conventional for all of its 16 years. When I did the LIM gaskets and valve cover gaskets, I cleaned the gunk under the valve covers which was not unsubstantial. I don't think the PCV valve was ever changed. I run PYB now and a Fram TG filter and it runs great with new plugs, wires, and very quiet with new tensioner and pulleys.
Its been several oil changes since the switch to PYB and the view down the oil fill hole is much improved. The years of bulk Castrol GTX left gold deposits and the lack of PCV valve maintenance probably contributed as well. Solid engine and transmission unfortunately with very poor build quality in the rest of the car.
2002 Oldsmobile Alero 3.4L
Re: 2002 Impala 3.4 engine [Re: thomasew] #4660448
02/08/18 10:38 PM
02/08/18 10:38 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
The 3.4 was known for cold startup clatter. It is caused by piston slap, and when the pistons warm up, they expand and fit tighter in the bore and the noise goes away. It doesn't really hurt anything, they will run a long time.
The main issue with those engines was the lower intake manifold gaskets. Keep an eye out for coolant leaks or milkshake looking engine oil from coolant contamination.
If you ever have to replace them, felpro makes an improved "ultraseal" kit that will last much longer than the original style.
Honestly, other than the intake gasket issue, they were a good engine. Good gas mileage for a v6 and decent power. Seen many of them go over 200k easy with proper maintenance.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: 2002 Impala 3.4 engine [Re: JHerriot] #4661973
02/10/18 02:06 PM
02/10/18 02:06 PM
North Carolina, USA
thomasew Offline OP
thomasew  Offline OP
North Carolina, USA
That has been my experience with this car, the motor and tranny are good for a lot of miles, but the rest of the car, it leaves a lot to be desired as far as build quality goes. I have had to get the intake manifold gaskets replaced at 53k. This was my mother's car, and she didn't drive it much, and never changed the anti freeze in it. It came to me b/c my mother was sick and she wanted me to check her car out b/c she was smelling anti freeze all the time. It was leaking out and getting on top of the motor, and the oil got in the radiator, etc. It was a mess but the car only had 53k miles on it when it was 11 years old, which was about the time I started driving it. When my mother passed away 5 years ago my Dad said he was going to quit driving and gave the car to me. I thought it was worth fixing with only 53k on it, so I took a chance on it. I have had to fix a few things, mostly due to it sitting all the time, IMO. It has really good power and pickup, and it gets mid 20's MPG, which for a big car like an Impala that was pretty impressive I thought. I have 120k on it now, and it still gets mid 20's mpg. thanks for all the input.
