Originally Posted By: mk378
The same, or lower on the top.
The bottom thermostat drives normal operation. It will only switch over to the upper if nearly all the hot water has been used. It is to quickly heat some water in the top of the tank.
I believe the top controlls..if its temp is reached it sends current to the bottom. I could be wrong.
