Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
91 registered members (55hambone, Ag76, Armkb, anndel, ABomb369, 14Accent, 14 invisible), 1,830 guests, and 31 spiders.
Topics290,954
Posts4,853,165
Members66,062
Most Online3,590
Jan 24th, 2017
Interesting oil extractor #4658556
02/06/18 11:43 PM
02/06/18 11:43 PM
CA
CharlieBauer Offline OP
CA
This oil extractor has an adapter that locks onto the dipstick tube using it to suck the oil out instead of a tube that is fed down into the pan.
I wonder if it leave a little in compared to piping a tube all the way to the bottom, or if the suction is so strong it gets everything.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Interesting oil extractor [Re: CharlieBauer] #4658574
02/07/18 12:08 AM
02/07/18 12:08 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I would think it definitely leaves behind some dirty oil and possible any particles sitting on the bottom off the pan. Is this widespread at Mercedes dealerships?
If you want the job done right......do it yourself.
Re: Interesting oil extractor [Re: CharlieBauer] #4658576
02/07/18 12:09 AM
02/07/18 12:09 AM
CA
raytseng Offline
raytseng  Offline
CA
this will only work if the dipstick tube goes to the bottom of the crankcase which is the case since mb cars are designed to have oil changed via extractor.
to answer question above its the correct way to change a mb engines oil. there is no drain plug.
most the dipstick tube designs for cars with drainplugs dont attach to the bottom of.the crank so you'd be sucking an air gap before you hit the oil.
Re: Interesting oil extractor [Re: CharlieBauer] #4658650
02/07/18 03:17 AM
02/07/18 03:17 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Well, isnít that how you are pretty much forced to do it with Most Auto engine driven Marine applications. They sell an hand pump suction rig that looks like an insecticide sprayer just for that. After all trying to fit a pan under therethat will hold 5 qts and not dump it all over while snaking it out after its full is a PITA.
Re: Interesting oil extractor [Re: CharlieBauer] #4658704
02/07/18 07:27 AM
02/07/18 07:27 AM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
This is exactly what Walmarts have. I have never seen that adapter before, must be something special for MB. Those pumps, at least the one my walmart has is very under powered.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
Re: Interesting oil extractor [Re: CharlieBauer] #4658738
02/07/18 08:18 AM
02/07/18 08:18 AM
Suburban Washington DC
atikovi Offline
atikovi  Offline
If you change oil regularly and change it when the oil is hot, there shouldn't any crud at the bottom of the pan
Re: Interesting oil extractor [Re: CharlieBauer] #4658842
02/07/18 09:48 AM
02/07/18 09:48 AM
Panama CIty, Florida
mahansm Offline
mahansm  Offline
Mercedes engines since at least the 1970's are designed with a dipstick tube running to the bottom of the oil pan. The manual claims that you can get more oil out of the engine using an extractor than you can by pulling the drain plug. This makes changes easy, as all the engines I've worked on that were built after 1979 had filters that I could reach from the top side. (1977 240 D filter had to be changed from below.)
'14 Honda CR-V (toad)
'09 Honda Odyssey
'99 Bluebird Wanderlodge 43 LXi
Re: Interesting oil extractor [Re: FordBroncoVWJeta] #4658849
02/07/18 09:56 AM
02/07/18 09:56 AM
CA
raytseng Offline
raytseng  Offline
CA
if it doesnt have the adapter and is underpowered then obviously it is not exactly what walmart has. similar but not exact
Re: Interesting oil extractor [Re: raytseng] #4658948
02/07/18 11:49 AM
02/07/18 11:49 AM
Reno, NV
redbone3 Online content
redbone3  Online Content
Reno, NV
Not really true. When you insert the tube into the dipstick you don't stop at the bottom of the dipstick tube, you stop when the tube hits the bottom of the oilpan. The extractor I have has a fairly stiff tube and doesn't stray from a straight line much. If you were using some really wimpy tube then your argument would be easier to defend.
2014 Passat Wolfsburg, 1995 Miata.
Re: Interesting oil extractor [Re: CharlieBauer] #4659081
02/07/18 02:09 PM
02/07/18 02:09 PM
Rockies
Scdevon Offline
Scdevon  Offline
Rockies
This is the only kind of oil change my air cooled VW sees. I got tired of pulling the strainer plate because there was never anything on the strainer and I bought a Pela extractor. I get exactly 2 1/2 quarts out which is the rated oil capacity. I change the oil so often in it that it really doesn't matter if every last drop gets removed or not.
I did my VW Golf diesel this way too because the plastic skid plate was such a PITA and the dipstick tube went right to the bottom of the sump and the oil filter was topside anyway. Great system if you have a car you can use it on.
2003 Mustang Mach 1. 32V 4.6 Liter. Motorcraft Syn Blend 5W30
1970 Mustang Convertible 302-2V Auto (Stock) M/C 10W30
1970 VW Beetle 1600 DP
Re: Interesting oil extractor [Re: CharlieBauer] #4659102
02/07/18 02:32 PM
02/07/18 02:32 PM
atikovi Offline
atikovi  Offline
Anyone worried about not getting all the oil out can first suck it out from the top, then go underneath and see how much more comes out the drain plug. If less than half a quart I wouldn't worry about it.
Re: Interesting oil extractor [Re: CharlieBauer] #4659199
02/07/18 04:15 PM
02/07/18 04:15 PM
CA
CA
Thinking about this again, the suction in the video has to be very high because there is (obviously) no oil in the dipstick tube. So it has to suck air in first.
With that much suction, it's probably capable of getting all the oil out of the pan and at least as much as a tube inserted that hits the bottom
Re: Interesting oil extractor [Re: CharlieBauer] #4659265
02/07/18 05:23 PM
02/07/18 05:23 PM
Reno, NV
Reno, NV
The Mercedes tube must go to the bottom, or it wouldn't extract the oil. The intensity of the vacuum is more related )by far) to the speed of extraction than to the completeness.
Re: Interesting oil extractor [Re: CharlieBauer] #4659292
02/07/18 06:08 PM
02/07/18 06:08 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
The vacuum gauge at about the 30 second mark shows a bit greater than -0.4 Not sure what the units are though.
Re: Interesting oil extractor [Re: CharlieBauer] #4659319
02/07/18 06:32 PM
02/07/18 06:32 PM
CA
CA
Forward to 6:14 in this video and he shows the adapter used for vehicles that don't have a drain plug and says there is no need for a wand for those.
The vehicles without drain plugs that don't need a wand inserted must have dipstick tubes that go down almost all the way to the bottom of the pan.
