Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
101 registered members (ARCOgraphite, Ag76, Altima2, AZjeff, acme, 2012AccentSE, 12 invisible), 1,954 guests, and 61 spiders.
Topics286,230
Posts4,904,734
Members67,582
Most Online2,967
Mar 10th, 2019
what are stat settings for 2 element elect heater #4658410
02/06/18 08:50 PM
02/06/18 08:50 PM
Coastal South Carolina
edwardh1 Offline OP
edwardh1  Offline OP
lower /higher?
upper higher? both the same (near each other)
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: what are stat settings for 2 element elect heater [Re: edwardh1] #4658418
02/06/18 09:02 PM
02/06/18 09:02 PM
USA
mk378 Offline
mk378  Offline
USA
The same, or lower on the top.
The bottom thermostat drives normal operation. It will only switch over to the upper if nearly all the hot water has been used. It is to quickly heat some water in the top of the tank.
Re: what are stat settings for 2 element elect heater [Re: edwardh1] #4658768
02/07/18 08:45 AM
02/07/18 08:45 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I would say the same. Somewhere between 120-125 degrees per what I have read.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: what are stat settings for 2 element elect heater [Re: mk378] #4658785
02/07/18 09:00 AM
02/07/18 09:00 AM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
I believe the top controlls..if its temp is reached it sends current to the bottom. I could be wrong.
Re: what are stat settings for 2 element elect heater [Re: edwardh1] #4658816
02/07/18 09:32 AM
02/07/18 09:32 AM
USA
mk378 Offline
mk378  Offline
USA
Yes the top thermostat and element has priority. After the top of the tank is hot enough, the bottom thermostat is enabled. But the top only comes on during initial startup or after someone rapidly uses all the hot water.
