oil plug sealing washers
It COULD be an 8 pack of 1mm thick washers with 14mm holes with the outer dimension omitted.
You never know which drizzle brained, iPod wearing, sugared-up, facially pierced, tattooed overdosing freak was assigned to write the specs.
I had to explain to a youngster that 10-32 machine screws didn't mean 10/32" but #10-32 tpi. You should've seen the expression (or lack thereof).
Originally Posted By: Trav
A misprint. LOL
Or a rectangle.
8mm ID, 6mm wide sealing face = 14mm OD and 1mm thick.
Wouldn't that make it a 3mm wide sealing face?
