Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
117 registered members (555, A1O, 2015_PSD, albenjoseph, 97f150, 69Torino, 14 invisible), 2,123 guests, and 63 spiders.
Topics286,156
Posts4,903,149
Members67,565
Most Online2,967
Mar 10th, 2019
2015 Cruze Tire Choice Recommendation... #4657863
02/06/18 11:55 AM
02/06/18 11:55 AM
Union County, PA
2James1 Offline OP
2James1  Offline OP
Union County, PA
General Rt43 Vs. Continental TrueContact T speed rating for both...looking for treadwear, winter traction, quiet
2005 Chevrolet Malibu V6
Castrol Edge HM 10w-40/ Purolator Pureone
2015 Cruze LT 1.4T
Dealer Oil/Filter
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4657884
02/06/18 12:18 PM
02/06/18 12:18 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
I put Conti Pure Contact on mine. I took a hit in mpg from the Goodyears that were on it but the handling and traction are way better.
2002 Silverado 5.3 0w-20 AMSOIL
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4657886
02/06/18 12:22 PM
02/06/18 12:22 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Both of those are good tires, made from the same company. The Continental TrueContact has a little better tread rating so might last longer. So if they are around the same price then get them. If the RT43s are a good deal cheaper then get them.
yup
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4657948
02/06/18 01:08 PM
02/06/18 01:08 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
Do you care about Low Rolling Resistance?
TrueContacts are designed and made for Low Rolling Resistances.
The Altimax makes no such claims
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4657965
02/06/18 01:32 PM
02/06/18 01:32 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Hankook 727 or 737.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2015 Cruze Tire Choice Recommendation... [Re: UG_Passat] #4658057
02/06/18 02:59 PM
02/06/18 02:59 PM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
Although the Altimax doesn't make that claim, so far I haven't noticed a loss of range on my Volt relative to the stock Goodyear Assurance Fuel Max tires that were on it before. I've only had the Generals about a week but my miles per kwh has been very consistent over the last 3 years so I would notice a loss.
Re: 2015 Cruze Tire Choice Recommendation... [Re: czbrian] #4658215
02/06/18 05:39 PM
02/06/18 05:39 PM
MN
oil_film_movies Offline
MN
If LRR is a thing for anybody, I would highly suggest the Michelin Energy Saver A/S tires. They are tops for LRR in tirerack.com tests, tops for LRR by GM-Chevy Bolt OE standards, and the same usage in Ford Focus Electric and the current Chevy Volt. Some evidence that Bridgestone Ecopias are almost as LRR though. OEM's are picking the Michelin big-time these days when CAFE or electric range really matters.
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4658382
02/06/18 08:23 PM
02/06/18 08:23 PM
USA
slacktide_bitog Offline
USA
If you want winter traction for an all-season tire, consider something with the 3-peak mountain and snowflake logo, like one of these:
Vredestein Quatrac 5
Nokian WRG3 or WRG4
Toyo Celsius
Godyear Weatherready
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4658487
02/06/18 10:22 PM
02/06/18 10:22 PM
Michigan, USA
FordFocus Offline
FordFocus  Offline
Michigan, USA
Michelin Defender T+H
BFGoodrich Advantage TA Sport
2005 Ford Explorer SportTac XLT Adrenalin
Michelin Latitude X-Ice Xi2 255/70R16
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4659078
02/07/18 02:08 PM
02/07/18 02:08 PM
NH
supton Offline
supton  Offline
NH
Haven't tried most of the others, but right now I like RT43's. Not the longest lived, not low rolling resistance: but good enough on all other counts. It's what I run on my two cars, and plan on buying again in the future.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: 2015 Cruze Tire Choice Recommendation... [Re: oil_film_movies] #4659159
02/07/18 03:21 PM
02/07/18 03:21 PM
California
nthach Offline
nthach  Offline
California
Bridgestone Ecopia is a LRR tire, but the OEM-spec ones for BMW/Lexus/Toyota are better than their aftermarket lines for that. It seems like Ford, GM and Honda use Michelin when CAFE or LRR matters - Tesla also installs Michelin most of the time. BMW and Toyota use Bridgestone. Toyota's been installing Toyo NanoEnergy or Yokohama BluEarth tires on the Prius, but the Mirai and the Lexus hybrids get Michelin Primacy MXM4s or Premier LTXs from the factory.
The Goodyear Integrity was the OEM pick for CAFE on cars a while ago.
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4659802
02/08/18 09:32 AM
02/08/18 09:32 AM
Michigan
Ben Boyle Offline
Ben Boyle  Offline
Michigan
My Verano came with the Continentals and I had 4 flats in 20k miles. I then got rid of them and put on Goodyears and put 50k miles without incident. Keep in mind it's the same size as a Cruze
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4659807
02/08/18 09:35 AM
02/08/18 09:35 AM
MA, USA
krzyss Online content
krzyss  Online Content
MA, USA
No wonder Goodyears had no flats. You swept the roads with Continentals!
Krzys
Re: 2015 Cruze Tire Choice Recommendation... [Re: 2James1] #4659816
02/08/18 09:42 AM
02/08/18 09:42 AM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
If winter traction is something you prioritize the Vredestein Quatrac 5 are a great value and available from tirerack now.
