My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
78 registered members (agpatel, alphadog, Aichiguy, bbhero, AdditiveOCD, 9 invisible), 1,392 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
2015 Ford 6.7 Powerstroke 38k oci broken crank #4657768
02/06/18 10:29 AM
02/06/18 10:29 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
2015 Ford 6.7 Powerstroke 5w40 Amsoil fully deleted and Amsoil dual remote bypass
Well 5 hrs after I took this oil sample and changed the oil the crankshaft snapped ruining the block
38,000km with a full flow filter change half way through
Oil sample looks great I am guessing there was a weak spot in the crank that finally let go? No lead so I don't think it spun a bearing first.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657783
02/06/18 10:42 AM
02/06/18 10:42 AM
Louisiana
SuzukiGoat Offline
SuzukiGoat  Offline
Louisiana
Why would you do this..
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657789
02/06/18 10:51 AM
02/06/18 10:51 AM
California
mbacfp Offline
mbacfp  Offline
California
Sorry to hear that. Thanks for sharing the OCI.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: SuzukiGoat] #4657796
02/06/18 11:02 AM
02/06/18 11:02 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Why would I do what? Oil sample came back looking great?
At 45ppm of Iron I am nearly 1ppm per 1000km that is phenomenal for a Hard Working PSD with lots of PTO Hrs IMO
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657801
02/06/18 11:08 AM
02/06/18 11:08 AM
California
mbacfp Offline
mbacfp  Offline
California
My Powerstroke is on my 35ft motorhome...and my Iron last 2 OCIs were 68, 63. Are you going to try and warranty it (assuming you can't due to delete)? Sorry for your bad luck.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657804
02/06/18 11:13 AM
02/06/18 11:13 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Please keep us informed on how Ford responds. You should be on the power train warranty, correct?
SF
If you want the job done right......do it yourself.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: mbacfp] #4657807
02/06/18 11:14 AM
02/06/18 11:14 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Originally Posted By: mbacfp
My Powerstroke is on my 35ft motorhome...and my Iron last 2 OCIs were 68, 63. Are you going to try and warranty it (assuming you can't do to delete)? Sorry for your bad luck.
You're a similar setup as this is also a F-550 but with a Vac tank on it, what is your OCI? truck is just out of warranty, a brand new long block is $7000 with 2 year unlimited mileage warranty.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657815
02/06/18 11:21 AM
02/06/18 11:21 AM
Louisiana
SuzukiGoat Offline
SuzukiGoat  Offline
Louisiana
When the engines start costing half the price of the vehicle, I err on the extreme side of caution.
Science be [censored].
Witchcraft at that point lol
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: SuzukiGoat] #4657821
02/06/18 11:26 AM
02/06/18 11:26 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Engine is 7000CDN
Purchase Price of truck 140,000CDN
it's far from half
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657822
02/06/18 11:26 AM
02/06/18 11:26 AM
California
mbacfp Offline
mbacfp  Offline
California
Here is a link to my OCIs.
https://www.bobistheoilguy.com/forums/ub...owe#Post4355305
I just had a upper oil pan leak which was luckily covered under warranty. My truck is always under load and 75% of the time flat towing a 5,000 pound Dodge Durango. 85% highway driving...hardly ever idles except to hook and unhook tow vehicle...currently have 21,800 mine. Take care.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657826
02/06/18 11:28 AM
02/06/18 11:28 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Anyone know the expected lifespan of a powerstroke? I assumed that 6000hrs was close to the end of the road anyway, I know Ford redesigned the 6.7 for 2017 and they promise it will make it to 10,000hrs, but they also promised the 6.0 was a great engine smirk
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657832
02/06/18 11:32 AM
02/06/18 11:32 AM
California
mbacfp Offline
mbacfp  Offline
California
Didn't they test them to hit 250,000 miles? My only real worry/concern was the turbo charger failing...I believe C&C trucks 2013+ have the turbo problem fixed.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: mbacfp] #4657841
02/06/18 11:37 AM
02/06/18 11:37 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
what is your engine hrs? I imagine its well under 1000 and still "breaking in" this truck also had a upper oil pan leak early on in its life, any reason for the additives? I used archoil on tired 6.0's with weak injectors but I don't see a reason to use it on a brand new engine with CR
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: mbacfp] #4657847
02/06/18 11:40 AM
02/06/18 11:40 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
250,000 miles @ 50mph is only 5000hrs, this engine exceeded that laugh looks like I got a good one.
The sister truck had a turbo go right before Christmas but I believe it was from lack of maintenance as I got a very poor UOA on it.
If your 2014 had the old [censored] ceramic bearing turbo it will blow soon enough and they will put a steel one in under warranty.
Re: 2015 Ford 6.7 Powerstroke 38k oci broken crank [Re: DustinC] #4657851
02/06/18 11:46 AM
02/06/18 11:46 AM
California
mbacfp Offline
mbacfp  Offline
California
I'm not sure on engine hours. I ran the additive primarily for extra turbo charger protection. My next OCI will not have any additives and I am planning on stopping due to advice on here. Been running Valvoline Premium Blue Extreme 5w-40 CJ4 and Mobil Delvac 5w-40 CJ4. My upper oil pan leak was fixed last September and I didn't get a sample...so my next OCI will be late May before summer trips.
Page 1 of 4 1 2 3 4
