Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
104 registered members (69Torino, 2012AccentSE, 2010Civic, 69GTX, 1978elcamino, 8 invisible), 1,805 guests, and 51 spiders.
Topics286,112
Posts4,902,848
Members67,565
Most Online2,967
Mar 10th, 2019
Kero Sun Radiant 8 Heater #4657706
02/06/18 09:25 AM
02/06/18 09:25 AM
Pennsylvania
wolfehunter Offline OP
Pennsylvania
So my dad gave me this kerosene heater he picked up at a yard sale for $5 and thought I could warm up my garage with it when changing oil or working on the cars. It looks in nice shape but there is no manual with it. Some lighting and extinguishing directions on the back of the unit is all. So I lit this thing last week and flames and black smoke is what I got so I put it out. I ordered a new wick and dumped all the old kerosene out as I found some minimal information on the internet and thought maybe a new wick and some fresh kerosene would do the trick. Took the entire unit apart, cleaned everything and replaced the wick but no instructions on how high the wick should be sticking out the top of the unit. The old one barely stuck out but I thought maybe it had become brittle and broke or burned off so no way to determine how high the new wick should stick out. There is a knob on the front of the heater that raises and lowers the wick about 1/4" and this knob when turned counter clockwise is to extinguish the flame. So I am thinking the wick must only stick up less than 1/2" but want to be sure before lighting it up. Don't want to burn the garage down! Does anyone have one of these heaters with a manual or does anyone know the correct height of a new wick?
Thanks,Scott
11 GMC Sierra 1500 100K
06 Toyota Sequoia 74K
07 Honda Accord 207K
70 Chevelle SS 112K
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657710
02/06/18 09:29 AM
02/06/18 09:29 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Why not phone your insurance company and ask them what THEY think.
If you want the job done right......do it yourself.
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657718
02/06/18 09:34 AM
02/06/18 09:34 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
As you've discovered, the kerosene heaters have a variable height wick, so that the "heat" can be turned up or down. There are plenty of youtube vids about setting wicks for heaters; check a few out and you'll get the idea. As long as you have the wick set to be closed out when the knob is turned "off", it should be fine. Also, depending upon the age of the unit, it might have a "tip over" counterweight that releases the knob to "off" if the unit gets kicked over by accident, to prevent fuel spillage and resulting fire. Make sure that is working right as well, if present.
If it's smoking, check the air-inlet small holes; if those are rusted, clogged, etc, they will screw up the A/F ratio and cause a sooty burn.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657720
02/06/18 09:36 AM
02/06/18 09:36 AM
USA
mk378 Offline
mk378  Offline
USA
The wick should be about 1/4 inch above the burner base plate when fully extended, and retract completely when the knob is turned to the off position so that the flame (eventually) goes out. In operation after warming up the flame should just come out of the top of the burner cage. It will not come up that high at first until the heater has warmed up. If you're getting high flames and black smoke it is too high. If someone has been running it like that you may need to clean soot out of the air holes as noted.
Test burn outdoors of course.
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657726
02/06/18 09:40 AM
02/06/18 09:40 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
This web site has all the information you will need on kerosene heaters miles stairs
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657767
02/06/18 10:29 AM
02/06/18 10:29 AM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
You can find an online manual
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657808
02/06/18 11:15 AM
02/06/18 11:15 AM
Pennsylvania
Pennsylvania
I tried searching for a manual online with no luck. Did see one on ebay for like $12 but was hoping to find one online. Will be more persistent. Where are the small air holes (breathers) located as I want to make sure they are not blocked. Thanks for all the help. Daughter's car needs a new driveshaft so hope to warm the garage up a bit to replace!
70 Chevelle SS 112K
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657816
02/06/18 11:23 AM
02/06/18 11:23 AM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Man this is a flashback to the 80's. Sounds like you had the wick turned up too high and it might need to burn for a bit. It shouldn't smoke and you shouldn't see any flame. If there is flame, it needs turned down a bit.
The wick should be about level, maybe stick up about 1/8". You do have the glass and wire canister looking thing sitting on top of the wick?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657842
02/06/18 11:38 AM
02/06/18 11:38 AM
Nowhere NM
Smoky14 Offline
Smoky14  Offline
Nowhere NM
Almost sounds like the chimney is missing.
Smoky......no pun intended
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657859
02/06/18 11:53 AM
02/06/18 11:53 AM
MN
Tman220 Offline
Tman220  Offline
MN
Yes the wick will go maybe 1/4"-1/2" above, but that is only to allow for lighting the wick and some adjustment for the burning of the wick.
once the wick is lit you need to keep retracting the wick until you get a clean burn. When the unit is warmed up remember, you are not actually burning the wick, you are burning the fuel being vaporized from the heat.
These heaters aren't designed to produce a lot of heat, so don't set your expectations too high. lower the wick until you get a clean burn.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4657953
02/06/18 01:22 PM
02/06/18 01:22 PM
northern NY
Driz Offline
Driz  Offline
northern NY
One thing about smoke with those is they usually smoke when you turn them on. After they settle down in a few minutes they are ok. They’re supposed to burn clear kerosene which can be easy or impossible to find depending on your area. We used to light ours outdoors and bring it in after it stops smoking.
Re: Kero Sun Radiant 8 Heater [Re: Driz] #4657992
02/06/18 01:57 PM
02/06/18 01:57 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Kerosene at our local Bomgaars is about $17.00 a gallon.
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4658428
02/06/18 09:15 PM
02/06/18 09:15 PM
Pennsylvania
Pennsylvania
I found a manual! Kero Sun was bought out by some toyotomi company and this RSA 8 is the same as the Kero-Sun Radiant 8. 1/5" is all that is supposed to be sticking up with knob turned all the way clockwise. And I am missing the glass globe, the heating coil and the wire net so will be checking to get thos eparts ordered. And yes, 8200 BTU's isn't going to light the world on fire in a 32'x32' garage but it is insulated so every little bit will help!
https://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20RCA,%20RSA,%20or%20SC/RSA%208.pdf
70 Chevelle SS 112K
Re: Kero Sun Radiant 8 Heater [Re: wolfehunter] #4658438
02/06/18 09:31 PM
02/06/18 09:31 PM
USA
mk378 Offline
mk378  Offline
USA
The electric ignition system is more trouble than it is worth. It's easy to light with a match or lighter.
You do absolutely need all the parts of the burner for a proper burn though.
Re: Kero Sun Radiant 8 Heater [Re: dishdude] #4658560
02/06/18 11:45 PM
02/06/18 11:45 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
80's ? We used kerosine heaters in the '50's, 60's and '70's...we might've still been using one in the early '80's. You could buy kero at the pump. My grandmothers heater took 2 half gallon jars of kero, when they ran out we'd walk down to the grocery store and get them filled.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
