What exactly is the A5/B5 and why is it dropping?
NM
What exactly is the A5/B5 and why is being discontinued or dropping out of all the future formulations?! I thought the higher the number the better the oil but I guess not.
The only oil I know offhand that meets A5/B5 is Pennzoil Platinum 5W-30.
I've decided it's probably easier and most likely better long term to just use an A3/B4.
The reason they no longer meet A5/B5 is because they can't pass a new test added to the ACEA 2016 sequence, but that new test is done on a diesel engine and really only relevant to diesels.
Castrol promised a revised formula that would meet the new A5/B5-16, but it doesn't seem to have been released.
Valvoline tries to use a disclaimer that their synthetic 5w30 meets A5/B5 for gasoline engines only, but ACEA does not allow this. If it doesn't meet the standards for both gas *and* diesel engines, it doesn't meet them at all!
Originally Posted By: bigjl
Also I don’t remember seeing an oil that was just A1/B1 for years they usually always meet A5/B5.
0w20 and 5w20 synthetics were A1/B1 but not A5/B5 because A5/B5 requires HTHS of at least 2.9,m whereas A1/B1 allowed an exception for __w20 where the HTHS could be 2.6
and as QP said, ACEA recently dropped A1/B1.
There were/are some in North America, but both those are somewhat uncommon.
The last A1/B1 only oil i saw was a Semi Synthetic and that was years ago now.
Its the spec that Fords used to specify in the UK before they introduced the Ford Specific spec
Our M1 products had just that for a while, not to mention any 20 grades that wouldn't normally get A5/B5 by reason of HTHS in the first place. Of course, as A5/B5-2016 was coming down the pipe, a M1 and Castrol got rid of A5/B5 and Valvoline was doing their A5/B5 but for gasoline engines only business.
Lots of euro 20 grades are A1/B1. They'll soon be C5 rated.
There are not many manufacturers that ask for A5/B5 in their gasoline enginess
