Originally Posted By: Wolf359
Well the only annoying thing about an MB oil change is that they have a plastic shield under the car so you have to undo those bolts first to get at the drain plug. And then the drain plug is sideways so oil gets all over the under body when it first comes out. Still rather do it myself and spend under $30 for the synthetic oil and fleece filter.
You're not extracting through the dipstick? Thought that's actually the recommended way.
While the oil is extracting, I do the filter. Very quick and virtually mess free.
