Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
84 registered (andyd, 2015_PSD, 93cruiser, ammolab, Astro14, 77GrandPrix, 13 invisible), 1478 Guests and 47 Spiders online.
65294 Members
67 Forums
285789 Topics
#4657423 - 02/05/18 08:49 PM Another Coolant Question?
maverickfhs Offline
Loc: VA
Somehow, I have ended up with a gallon of an Audi Coolant. Don't plan to use in any of my Honda.
It says, safe to use in Aluminum engines, but also list silicates in content.
Looking here: http://www.machinerylubrication.com/Read/841/coolant-fundamentals
Can some of these silicates present in European car coolants cause problems with Water pump, as well as seals and all?
If so, why does the bottle say safe to use in AL engines? shrug
Does anyone know if this coolant is going to be safe for AL engine or no?
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4657433 - 02/05/18 09:11 PM Re: Another Coolant Question? [Re: maverickfhs]
PeterPolyol Offline
Loc: toronto
It would work meaning it has a suitable inhibitor chemistry for aluminum engines, but AFAIK the Japanese don't use any silicates in their coolants. Silicates can agglomerate into larger particles and fall out. Not personally a fan of silicate sand in my coolant, softly sandblasting impellers and abrading seals. The Japanese OEMs probably don't like that prospect either, and they only have the most reliable cooling systems around IMO. wink
#4657435 - 02/05/18 09:13 PM Re: Another Coolant Question? [Re: maverickfhs]
Reddy45 Online   shocked
Loc: USA
Silicates are a problem if the internal components weren't designed for them, or if the silicates fall out of suspension right?
But the amount of silicates present in a modern coolant would be drastically less than in the old school formulas. A HOAT coolant like Zerex G05 is going to have some silicates, some organic acids.
So worst case -- if you use the coolant, change it out after 3 years/36k miles.
#4657915 - 02/06/18 11:47 AM Re: Another Coolant Question? [Re: maverickfhs]
KrisZ Offline
Loc: Toronto, Canada
Not a problem. There was some concern with water pump life with the old, fully silicated formulas, but it's nothing like "sandblasting" any internal components. Another internet myth that just won't die. Japanese mostly avoid silicated because of their local water supply, which is I think soft water, so they use phosphates. In Europe they have very hard water and silicated formula works better in that scenario.
Reality is that today's low silicate formulas have no bearing on cooling component life what so ever.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4657994 - 02/06/18 01:02 PM Re: Another Coolant Question? [Re: KrisZ]
PeterPolyol Offline
Loc: toronto
Low-silicate is better to alleviate the problem of dropout and abrasion, but it's just that- low silicate, not no-silicate. The presence of silicates doesn't automatically mean system failure, but the means of dropping out and becoming circulating abrasives well remains and that's still a difference. Silicates are obsolete IMO!
#4658024 - 02/06/18 01:29 PM Re: Another Coolant Question? [Re: PeterPolyol]
KrisZ Offline
That's why you change the coolant. If you want to go 10 years between coolant changes, then I agree, you have to drop silicates, but if you're fine doing it every 5 years, silicates pose no problems and will not drop out.
I've been running G-05 in my Mazda 3 for close to 10 years now. No problems as long as no mixing with other formulas is allowed and the coolant is changed per recommendation.
#4658028 - 02/06/18 01:31 PM Re: Another Coolant Question? [Re: maverickfhs]
maverickfhs Offline
Loc: VA
I guess, Audi coolant is same as G-05 so thanks for answering the question.
