WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
20 registered members (DirtyOilGuy, CleverUserName, BlakeB, chance, 2015Corolla, ctechbob), 754 guests, and 34 spiders.
Topics290,810
Posts4,850,743
Members66,036
Most Online3,590
Jan 24th, 2017
Do dirty pistons really affect performance/economy #4657025
02/05/18 03:10 PM
02/05/18 03:10 PM
NM
tempnexus Offline OP
NM
Do dirty pistons really affect performance/economy or is it only a cosmetic issue? Like people who say that car runs better after a car wash or engine runs better after they rinse the top of the engine etc.
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657031
02/05/18 03:14 PM
02/05/18 03:14 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
piston deposits (light) is mainly cosmetic IMO, heavy piston deposits can cause issues... such as preignition.excessive wear, stuck rings..etc
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657044
02/05/18 03:25 PM
02/05/18 03:25 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
I think the answer here is eventually. Once piston deposits start and no action is taken to resolve or reverse them they continue to build and as mentioned already the result is stuck rings, hot spots etc.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657065
02/05/18 03:49 PM
02/05/18 03:49 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I think the worst thing to worry about is if you gum up the area underneath the rings, but the chances of that with modern synthetic oil is next to nil. I guess clean pistons can't hurt.
If you want the job done right......do it yourself.
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657066
02/05/18 03:50 PM
02/05/18 03:50 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
light crud on the skirt - cosmetic.
Crud anywhere in the rings - its real.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657089
02/05/18 04:10 PM
02/05/18 04:10 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Ring coking is a big problem. It causes the rings to seal shut, blow by, and high oil consumption that can lead to cat failure.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657125
02/05/18 04:31 PM
02/05/18 04:31 PM
NM
NM
Thanks all.
Now the question is: Do any additives actually clean the pistons if the engine is direct injection like the Volvo Drive-E engines?
If not then how does one go about cleaning them? (pull the plugs, soak the piston in let say starter fluid ?)
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657140
02/05/18 04:44 PM
02/05/18 04:44 PM
CA
raytseng Offline
raytseng  Offline
CA
There is no logic in the direct injection as a problematic variable for an additive for piston cleaning. The additive will clean a DI piston the same as a regular fuel injection.
Did you mix this up with valve cleaning?
That being said any of the pea additives will work, I will recommend redline si1. You can youtube redline si1 reviee and a couple people have taken before and after borescope shots where it cleans. It is realistic as its not 100% clean but you see it working.
Finally if your system is already clean enough there is not going to be any difference in your vehicle behavior.
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657153
02/05/18 04:56 PM
02/05/18 04:56 PM
Florida
Artem Offline
Artem  Offline
Florida
Well, if the piston top deposits build up to an extent where the engine's compression ratio becomes effected, that will certainly cause a performance change, wouldn't you say?
Deposit control is a MUST, in my opinion.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657184
02/05/18 05:24 PM
02/05/18 05:24 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Bestest way I know to control carbon build up is the funnest too. The Italian tune up grin2
Thick oil is better grin2
Re: Do dirty pistons really affect performance/economy [Re: andyd] #4657225
02/05/18 06:09 PM
02/05/18 06:09 PM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
Absolutely! I do a combo effect of dosing with Redline SI-1 while doing it. Fun and healing at the same time (done safely of course).
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (74K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (70K)
>EDGE 0W-20, Fram XG6607
Re: Do dirty pistons really affect performance/economy [Re: WhizkidTN] #4657273
02/05/18 06:56 PM
02/05/18 06:56 PM
wv
krismoriah72 Offline
wv
There are many youtube videos of guys cleaning piston tops and combustion chambers with various products, they have proof of good/bad with boroscopes.
I havent seen a water mist video yet perhaps there isnt one..but water as far as i know cleans combustion chambers the best.
Does it matter one way or another? No proof of performance or economy that i have ever seen.
There are lots of engines that make it way past 200-400K miles with nothing done but routine maintanance.
IMHO most of the ring coking and blowby issues are due to manufacturing defects using poor designs or bad products..
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657349
02/05/18 08:19 PM
02/05/18 08:19 PM
ME
eljefino Offline
eljefino  Offline
ME
I've done MMO/ Seafoam/ Water mist cleans of old saturn s-series.
They burn oil and the coke from that leads to preignition/ knocking, which leads to ignition retard, and flat spots/ terrible performance.
All three methods clean great. So does running a 15w40 oil.
Re: Do dirty pistons really affect performance/economy [Re: eljefino] #4657368
02/05/18 08:32 PM
02/05/18 08:32 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
Same thing in my saturns, I used berryman b-12 1/2 can every 3rd tank, and rev it good when hot.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Do dirty pistons really affect performance/economy [Re: tempnexus] #4657407
02/05/18 09:21 PM
02/05/18 09:21 PM
Oregon
MrQuackers Offline
MrQuackers  Offline
Oregon
That sc1 has been at 185k for a long time now.
Master the 1000 yard stare
coffeeMobil 1 USA
